Operator Console
To week 1 teams (or anyone with previous experience): has anyone successfully received data from switches connected to the operator console to select autonomous routines? I just want to ensure that the packets are sent and that we don't run into trouble on practice day with this.
Thanks! |
Re: Operator Console
we have our autonomous selector switches on our robot. we read the switches at the beginning of autonomous and select a mode from there. If you don't have success with switches on the operator console, you can always to this and put them on the robot.
Yeah we've typically done the robot switch because we thought it was the only way, but I noticed in the basic LabVIEW framework that they read data from the operator console in the autonomous independent VI. I want to see if teams have used this successfully.
Yes, we have successfully received data from our switches on the I/O Module and have used the switches to select auton routines. We just used the Enhanced IO vi in LabView to use the data.
Last year we did this. We just went into the I/O panel of the DS and and set them in there, rather than hook up the board.
We did it with the joystick throttles last year, and this year we're putting on a few switches and potentiometers to choose the mode.
Just read the switches and stuff during disabled. It's probably a good idea to display the information to the dashboard also. |
Cool, thanks everyone. Out of curiosity, why does it have to be in disabled, rather than autonomous independent? Also, what is the Enhanced IO vi?
Matt |
The DS compatible I/O can be virtual -- set on the screen -- or via the Cypress board. The enhanced I/O is far more flexible, but is not virtual. You must use the board with enhanced I/O. Greg McKaskle |
