Go to Post This is what I love about FIRST everyone helps and asks why later. - Kyle [more]
Unread 05-03-2011, 10:44
Brandtlamonte Brandtlamonte is offline
FRC #2080
Brandtlamonte is an unknown quantity at this point
Hard drive magnet mounts
Can anyone offer a suggestion as to how the hard drive magnets for minibots could be mounted with the new GDC ruling that the brackets have to come off? Thanks
Unread 05-03-2011, 11:38
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Hard drive magnet mounts
You could try using either of the two allowed glue classifications (polycarbonate or PVC) or you could simply use normal hardware using an edge clamping method.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 05-03-2011, 13:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
.030 polycarb sheet as a strap over it?
Unread 05-03-2011, 14:35
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
I thought the glue used in manufacturing was likely epoxy, but another poster reported that he'd actually removed the bracket by prying, and it appeared to be cyanoacrylate. If that's the case, you could soak the magnets for a few days in acetone to try to loosen them up—acetone dissolves cyanoacrylate, which is the main component of most superglue. (Unfortunately, the bond gap is usually so thin with cyanoacrylate that it may take quite a while to diffuse in. Gentle, continuous agitation may help.)
As for brackets on or off, have a look at the discussion in this thread.
Unread 05-03-2011, 14:52
FRC #2080
Removing them really isnt my problem, mounting them is. Any suggestions?
Unread 05-03-2011, 15:39
Rookie Year: 1999
Then the super-thin polycarbonate sheet is your best bet. You can find stuff as thin as 0.005 in on McMaster-Carr's website.
