Go to Post To limit FIRST to robots, tools, and competition is to strip away its immense potential. - Madison [more]
Unread 06-03-2011, 15:24
ENIAC's Avatar
ENIAC ENIAC is offline
AKA: Matthew Petersen
FRC #5958 (Blue Wave Robotics)
Team Role: Coach
ENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the rough
Safety lights
Does anyone know what a solid light means, or if there is a manual for it somewhere?
Unread 06-03-2011, 15:57
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: Safety lights
If you are referring to the robot status light, I would check to see if the jumper is installed properly as shown in this document
blink codes are here
http://decibel.ni.com/content/docs/DOC-3120
EDIT: oh, wait, for some reason I skimmed right past steady on in the list. Maybe there is nothing wrong after all (at least with the light).
Unread 06-03-2011, 16:09
ENIAC's Avatar
Team Role: Coach
Re: Safety lights
Thank you. Our robot was acting up on bag and tag ( ) and one of the symptoms was a steady on with occasional flashes of off. It may have been a jumper, but it doesn't explain the rest of it.
Unread 06-03-2011, 16:29
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Safety lights
Fast Blink = not communicating
Slow Blink = disabled
Long on/short off blink = Teleop mode (what you described)
Solid on = Autonomous mode
Unread 06-03-2011, 19:17
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Safety lights
Mark,
Last year, they went to five codes as follows:
Solid ON = Autonomous Enabled
Solid ON, but blinks OFF every 1.5s = Teleoperated Enabled
Slow Blink (900ms on/ 900ms off) = System Disabled; caused by system watchdog, user watchdog or Driver's Station set to disabled
Fast-Slow Blink (200ms on/900ms off) = Low Battery (<12V) or no user code AND system disabled either by system watchdog, user watchdog, or Driver;s station set to disabled
Fast Blink (200ms on/200ms off) = System error: No driver's station communication, bad cRIO Image, bad team ID, extensive comm. error
I have seen no documentation this year so I assumed it was the same...
Do you have a link to current (2011) blink codes?
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
