Re: Motor for arm: what should be used when?
(and ideally below the max power rating). It should supplement our spring counterbalance nicely. |
David Last edited by 2829ron : 07-03-2011 at 23:28. |
Let's say you've got the equivalent of 5 pounds at 6 feet from the pivot, or 30 foot-pounds of torque. From these two numbers you can calculate the required mechanical power in watts: 90 degrees per second = 15 rpm (15 rpm)*(30 ft-lb)/7.043 = 63.9 watts Now using the motor curves, or this simple calculator, you can find that the CIM motor speed which generates 63.9 watts at 12 volts input is 5045 rpm. Since 5045 is 95% of the CIM's free speed, it should run cool at this operating point. Take the ratio of the motor rpm to the arm rpm to get the required gear ratio: 5045/15 = 336:1 gear ratio. If you use a gear ratio much less than this, you will either get an arm which moves so fast that it is uncontrollable, or you will have to operate the motor far outside its design point which can cause overheating. The CIM is can tolerate a lot of abuse but it is not immune to burn-out. Last edited by Ether : 07-03-2011 at 18:14. |
We used the sprockets from the wheels and put them on the arm. This is attached to a chain running to the toughbox.
David P.s. Parallel to the ground not vertical ![]() |
We use only 1 window motor to drive the 62" arm. Needless to say, it gets burning hot. So we put a heatsink with a fan on it (I don't know if it is legal)
Which fan?
You'll have to replace it with one provided in the KOP to be legal under <R45> and <R46>.
We're running our arm on one Banebots 550 and one Fisher Price. We were going to use the Andy Mark Double Doozy but it wasn't available, so we designed and built our own custom gearbox. The internal reduction is 237:1 plus another approximately 3:1 reduction from the sprockets.
So far the motors have been getting warm but not hot under match level or higher stress environments. We did have to do a lot of work in software to keep the arm from sinking but even that doesn't seem to be putting too much strain on them. |
#10
We have two window motors hooked up to a 20:3 (~7:1) gear ratio to a 40" upper arm, on which is attached another window motor hooked up by timing belt ~3:1 to a 33" lower arm with a pneumatic claw attached to the end adding length and weight. We never had any problems with our arm lifting, but we have four strands of surgical tubing just in case.
Last edited by Kyoshirin : 09-03-2011 at 14:23. Reason: Had the gear ratios backwards and had wrong arm measurements. |
