Go to Post I think that in general people should worry more about what they are doing, and less about what others are doing. That goes for a lot more than FIRST. - pfreivald [more]
Unread 07-03-2011, 12:51
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
pic: K-Botics Team 2809, Kasey III (aka Barbra Streisand)
Unread 07-03-2011, 12:53
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Re: pic: K-Botics Team 2809, Kasey III (aka Barbra Streisand)
Awesome looking robot.
Can you elaborate on your autonomous mode. Which parts are read back from the recorded driver inputs and which parts use the senors? How is the data from both sources combined to give a consistent autonomous?
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 07-03-2011, 13:04
Jno
I am not the expert but this is how I understand it:
We line up the robot on the line, flip a switch on the robot that will record all driver inputs to the crio's memory. Then the Driver holds down a button that follows the line and stops at the wall using the T of the line and IR distance sensors, the operator then operates the arm as this happens and scores the tube. Then after the tube is scored the driver can drive the robot to midfield ready to pickup a tube when teleop stars. Then when we flip the switch to play back and line the robot up again, it uses the recorded driver/operator input and the same sensors as it did before. I think there are a couple other things we are doing but thats basically it. We will see how it works this weekend, but it looked promising on our practice field.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 07-03-2011, 13:22
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
Very nice!
Are those rotating lights? I'm getting 2002 flashbacks.
Also, that swing arm looks very familiar. Does it have any in/out adjustability to permit operator alignment error? With mecanum and the ability to strafe, this shouldn't be as big a concern for your team relative to one that has a standard xWD drivetrain.
And Banebots has to be loving the run on puke-green Banebots wheels this year. :-)
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 07-03-2011, 16:15
Jno
Originally Posted by Travis Hoffman View Post
Very nice!
Yea we have an old 610 robot in our lab from '02 that had one of those old rotating lights and one of our students contacted American Signal Company and got the three on our robot donated. With how the game is developing not sure how much use we will get out of them, but they sure are pretty.
The swing arm is basically ram into the base and as long as the robot is touching the base it swings the minibot into the pole.
Yea those banebot wheels are nice, the tread is really gummy, nice and light, come with a 1/2" hex. We need to clean ours off a bit, they got pretty dirty when practicing at our sponsors wear house.
Unread 07-03-2011, 16:16
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
Regarding your unique autonomous stratagy:
First: wow, a great idea that, as you describe it, seems like a great solution.
Second: how do you record inputs to be used after the robot is reset?
Unread 07-03-2011, 19:20
Jno
I believe it literally outputs all the driver control inputs into a .txt file on the crio's memory, then plays back those driver inputs into the code during autonomous.
Unread 07-03-2011, 20:31
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
Caution!
Some teams have been having problems with the lines being scuffed up and their line sensing stuff not work. So caution to you guys, AND MAKE SURE THE REFS REDO THE LINES IF YOU GUYS EVEN FEEL A LITTLE BIT WORRIED ABOUT SCUFFED LINES.
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
Unread 07-03-2011, 21:50
Mentor_Mike Mentor_Mike is offline
Mentor/Student/Wishful Thinker
FRC #2809 (K-Botics)
Mentor_Mike will become famous soon enoughMentor_Mike will become famous soon enough
As for the lines, ours weren't brilliant to begin with, but it's definitely something we'll have to watch out for.
Mentor (2008-present)
610:
Mentor (2005-2007)
Team Leader - Driver (2004-2005)
Operator (2004)
Non-Mechanical Head (2003-2004)
Code/Grease-monkey (2001-2003)
Unread 07-03-2011, 22:08
coldfusion1279 coldfusion1279 is offline
AKA: Mike
FRC #1279 (Cold Fusion)
Team Role: Coach
coldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud ofcoldfusion1279 has much to be proud of
thumbs up for the music.
I like your robot too...
Cold Fusion's 10th Season
Unread 07-03-2011, 22:48
Thuvishan.R's Avatar
Thuvishan.R Thuvishan.R is offline
FRC #1241 (THEORY6)
Team Role: Coach
Thuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant futureThuvishan.R has a brilliant future
Very nice, wouldn't expect nothing less from such a great team, cant wait to see this up close in person at GTR
Thuvishan Rajagulasingam
Team 1241 THEORY6 Robotics- Alumnus
Rick Hansen Secondary School
2013 FIRST World Champions (1241, 1477, 610)
