Camera responding to wrong joystick buttons
Ok so I thought I programed the camera to respond to the 2,3,4,5 buttons on one joystick and on the other joystick I have stuff already assigned to these buttons. But when I press the buttons assigned to the other stuff the camera also respond to it. But does not respond if I press buttons 2,3,4,5 on the joystick I assigned it. I also have attached the program so you can look at it if needed. Any help would be greatly appreciated.
Re: Camera responding to wrong joystick buttons
It looks like you have a space after "joystick 2". If you don't have a corresponding space in begin where you set the device reference, you have a problem. I think it may be possible for an invalid joystick device reference to reference the joystick 1.
Also, check the joystick positions on the Driver station Setup tab.
push a button and the USB it's associated with will turn blue. Make sure the camera joystick is where you expect it to be. |
