Go to Post I saw a big opening in the bees section and asked if we could sit for this match and was told we were welcome to sit there. Your team made space for about 15 of my team members that came with me. - Debbie [more]
Unread 07-03-2011, 22:29
1293minibot 1293minibot is offline
Team 1293
AKA: Chris Dickey
FRC #1293 (1293)
Team Role: Mechanical
Rookie Year: 2010
1293minibot is an unknown quantity at this point
Exclamation Tetrix motors
Watch out! Our motor connecters were bent too much and one of them broke off. We are buying more but they are extremely expensive so be careful.
Unread 08-03-2011, 09:33
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Tetrix motors
Everyone should take at look at the Tetrix motor cable:
http://shop.pitsco.com/store/detail....2&s=32&ID=5478
I didn't know about them until I saw teams using them at Manchester. Very helpful to protect the fragile connectors on the (exposed) end of the motors. At $2 a lot cheaper than a new motor!
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 08-03-2011, 09:40
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Tetrix motors
Install zip tie strain relief on the motor feed wires which will also help.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
