Go to Post When you tell any of your kids that winning isn't important, or isn't [I]that[/I] important, the flapping sound you hear is your credibility flying away. - jlindquist74 [more]
Unread 10-03-2011, 12:19
sheleski sheleski is offline
None #0910 (Foley Freeze)
sheleski is an unknown quantity at this point
Question Device Get References - Best Practice Question
Since this is my first year as Mentor and using Labview I have a best practice question concern device get references.
Should a device get reference be use once or multiple times with the same vi?
Steven
Unread 10-03-2011, 12:43
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Device Get References - Best Practice Question
I can't say it's the best practice, but I try not to duplicate things when I can just wire the existing value to multiple places.
Unread 11-03-2011, 06:49
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
I agree with Alan. The main idea is to use the Set Reference once (typically in Begin.vi). Then use the Get Reference where needed - typically once in other VIs like Autonomous and Teleop. You could use it multiple places in Teleop, but it might eventually make your code harder to read and maintain.
They main reason we introduced the Set Reference and Get Reference was to encourage the use of a single Open VI in Begin.vi. Otherwise we found it was common for teams to use one Open in Autonomous, and then the same Open in Teleop without using a Close first. This would cause errors - trying to open a resource that was already opened.
Doug Norman
