Go to Post If you're in Israel, it might be a long flight to the nearest Walmart - MrForbes [more]
Unread 10-03-2011, 14:22
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is online now
John Rangel
FRC #0842 (Falcon Robotics)
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
Minibot Pole Diameter
Hello, we are pretty confused on what the size of the minibot pole is. On the field dimensions, it shows the pole hole on the base has a diameter of 1.75". However, for the diameter of the pole, there is no information I can find. Does anyone know what the diameter for the pole is or where we can find the dimensions.
Thanks
2011-2014 Arizona Regional Winners
2012 Dean's List Winner
2012-2013 Team President
2013 8th Place Robosub Competition
2014-? Mentor
Unread 10-03-2011, 14:31
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Minibot Pole Diameter
The answer you seek is in the 2011 FRC Game Manual, Section 2 - The Arena.
The POST is constructed from a piece of 1.5” Steel Electrical Metal Tubing (EMT) with a nominal outer diameter of 1.74”.
