Go to Post What am I going to do with all of these torches and pitchforks now? - PayneTrain [more]
Unread 11-03-2011, 19:01
willson.thomas willson.thomas is offline
FRC #1595
willson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nicewillson.thomas is just really nice
Question Task FUNCPTR Issue
I am having trouble defining a task. The code and compiler errors are below. If anyone knows what I'm doing wrong, help would be greatly appreciated!
Error:
Code:
C:/windriver/workspace/2011CompetitionCode/Arm.cpp:132: error: argument of type `int (LogomotionArm::)(LogomotionArm::ArmInitArgs*)' does not match `int (*)(...)'
Function Definition:
Code:
int InitialiseArm(ArmInitArgs *argsPTR)
		while (argsPTR->armJagTask->GetForwardLimitOK())
			argsPTR->armJagTask->Set(1);
			Wait(0.01);
		argsPTR->armJagTask->Set(0);
		argsPTR->armPositionTask->Reset();
		argsPTR->isInitialisingTask=false;
		argsPTR->isInitialisedTask=true;
		return (int)0;
Task Initialisation:
Code:
Task armInit("ArmInit",(FUNCPTR)(InitialiseArm));
		armInit.Start((INT32)(&initArgs));
Thanks!
Team Leader
Team 1595
Unread 11-03-2011, 19:42
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
Rookie Year: 2007
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Re: Task FUNCPTR Issue
Team 166's Framework166 deals with this. We don't actually use the WPilib tasks, but we DO typecast our tasks into FUNCPTRs.
The main code we use is
Code:
static int MainJacket(void *this_p, int a0, int a1, int a2, int a3, int a4, int a5, int a6, int a7, int a8);
Although I can't find the actual definition of FUNCPTR, from our code it's safe to assume that your task needs to take the same inputs as the MainJacket function snippet...or at least the same types. (There are almost certainly better names for the ints)
EDIT: This old thread mentions that the task has to have int arguments...
EDIT2: I just found it:
Code:
typedef int 		(*FUNCPTR) (...);     /* ptr to function returning int */
This basically means nothing that we don't already have by now, but it's a function that takes an int and, I believe, all int arguments.
GSR Dean's List Finalist 2011
