Airsoft gun Clip modification
So, I've got a firepower A47 Beta (http://www.airsocom.com/47390B6.html), and the crank for the clip broke. The shaft that it would plug into fits a 3mm allan wrench perfectly. I want to mount a small motor that can run the gear to load the airsoft gun while I hold the trigger. I'm Not sure where to get one, and that so far is my only problem
The motor would be around 120 rpm speed I think, and a somewhat low torque so it doesn't break the clip, likely with an either a keyed axel that can hook up to the proper allan, or a 3mm hex axel. I figure this is the best place to ask. |
Re: Airsoft gun Clip modification
Also, I would probably run it off of AA batteries or 9volt probably
A 6 volt black and decker screwdriver has about that speed and a .25 inch hex output, however, it might have a bit too much torque, Also, it is large but most of the casing can be removed easily.
The price here is $22 but Last year I bought 3 for ~12 dollars each at target and ~$10 at walmart. http://www.blackanddecker.com/power-tools/AS600.aspx |
It's a MAGAZINE, not a clip. I got this beat into me in boot camp. Clips are used to strip load a weapon. Magazines are inserted into a weapon. Just thought I'd pass that along.
