Go to Post The major items of FIRST are still what they always were.....understand the game, build a reliable quality machine to play it, train you drivers to use it to its full potential. If you do these things, you can win with or without any specific machine feature. - Jim Zondag [more]
Unread 13-03-2011, 16:28
HarveyAce's Avatar
HarveyAce HarveyAce is offline
FRC #3329 (CAMBots)
Team Role: Leadership
Rookie Year: 2010
HarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant futureHarveyAce has a brilliant future
Re: PID Loops
Originally Posted by Ether View Post
What is your total gear ratio from motor to arm (gearbox plus external gears or sprockets or pulleys etc).
We are currently running two denso window motors in tandem to power the joint with a surgical tubing counter balance. I'm just curious because when we ram the fp, it was WAY too fast and couldn't hold the weight in one position, but I've seen teams do it with much success.
"Though I fly through the Valley of Death I shall fear no evil, for I am at 80,000 feet and climbing."
Unread 13-03-2011, 16:53
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: PID Loops
when you "ran the fp" how did you run it? i.e. what total gear ratio did you use?
Unread 13-03-2011, 16:55
Ether's Avatar
Rookie Year: 1969
Re: PID Loops
In an earlier post, you mentioned 30-35 ft-lbs of torque on the arm. Was that with or without the surgical tubing in place?
Unread 13-03-2011, 14:43
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
Re: PID Loops
Originally Posted by theNerd View Post
when PID loops are used?
An example of a use of PID is our autonomous mode. We want to be able to drive out exactly x inches to our rack in a perfectly straight line to put us in a position to score a tube on the high rack. This isn't so straightforward as a 150lb robot has a lot of momentum and it is easy to overshoot a target distance (and crash into the wall). We can record the distance the robot has traveled by putting an encoder on the right side of the drive train. Using PID, we set the set point to x and read the encoder to get the current position. With our gains set correctly, we arrive at distance x rather smoothly.
However, we also want to drive in a perfectly straight line. If, say there is more friction on one side of the drive train, this will cause the robot to drive in an arc. You can add a gyro to the bot, use PID on it with the set point of whatever heading is defined to be "straight". Add this correction to the speed of the left wheel motors and you are 80% of the way to having a perfect one tube autonomous mode.
Unread 13-03-2011, 15:21
PriyankP's Avatar
PriyankP PriyankP is offline
FRC #0188 (Woburn Robotics)
PriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud ofPriyankP has much to be proud of
Re: PID Loops
I've been reading this thread and could someone please post an example code with P, I and D implemented to control something? I saw the LabView code, but I never learned labview, so could someone please post a C++/Java example?!
EDIT: I did implement P loop to control our arm this year, but only for presets. Is it possible to implement PID loop for manual control? If yes, how so?
Champs Schedule Highlighter App [CD Thread]
#### XYZ Regional Finalists
Unread 13-03-2011, 15:44
Ether's Avatar
Rookie Year: 1969
Re: PID Loops
Instead of preset, make the setpoint manually adjustable (like the output of a joystick axis) .
Unread 13-03-2011, 15:53
PriyankP's Avatar
Re: PID Loops
So it would be something like target = currentPotValue + (Yaxis * 5) right?
I'm multiplying by 5 because the Yaxis is only between -1 and 1 so one would want to have a target that is significantly different compared to the currentPotValue
Unread 13-03-2011, 16:02
Ether's Avatar
Rookie Year: 1969
Re: PID Loops
Yaxis is your setpoint and (m*currentPotValue+b) is your process variable.
Adjust the gain "m" and the offset "b" so that your process variable corresponds to your Yaxis output.
Then,
error = setpoint - process_variable;
motor_voltage_command = Kp*error;
Kp is your proportional gain which you tune for the desired response.
Unread 13-03-2011, 16:14
PriyankP's Avatar
Re: PID Loops
Then,
So (m*(currentPotValue+b)) should have range of -1 to 1? or it doesn't matter because Kp takes care of that?
Unread 13-03-2011, 16:52
Ether's Avatar
Rookie Year: 1969
Re: PID Loops
Kp does not take care of that. Kp is the tuning constant, and is applied to the error. Take another look.
Unread 13-03-2011, 17:35
PriyankP's Avatar
Re: PID Loops
So (m*currentPotValue+b) doesn't have to be within -1 to +1? And what exactly does it, the process variable, do?
Unread 13-03-2011, 17:43
Ether's Avatar
Rookie Year: 1969
Re: PID Loops
"m" and "b" are constants which you need to calculate and set so that the operating range of the process variable corresponds to the desired operating range of the joystick, be it -1 to +1 or 0 to +1 or whatever.
Read this post, then ask if it's not clear.
Unread 13-03-2011, 17:59
PriyankP's Avatar
Re: PID Loops
Am I correct about this:
JoyStickYaxis is +1 (operator input)
currentPotValue is 550 (min is 300 and max is 600)
(m*(currentPotValue+b)) = ( (1/150)*(550-450) )
m is 1/150 and b is -450 so that the number is always between -1 and 1
error = 1 - 0.6666;
MotorOutput = k * 0.3333 and say k is 0.75 then the output becomes 0.25
of course, k needs to be adjusted so the error is as close to 0 as possible and/or the arm doesn't oscillate
Good so far? Or did I make a mistake somewhere?
EDIT: I have a feeling I did something wrong
Unread 13-03-2011, 15:55
Chris27's Avatar
AKA: Chris Freeman
Re: PID Loops
If a system of your robot has mechanical limits (e.g. an arm) you may want to use PID (or even just P) to not smash into those limits. I can also see PID used for speed control like in Chris's example.
