Go to Post "The only constant is change" is a hint that probably applies to every season of FIRST. - Chris is me [more]
Unread 12-03-2011, 17:03
jhellr13 jhellr13 is offline
FRC #4272
Rookie Year: 2010
jhellr13 is an unknown quantity at this point
Arcade mecanum drive
I have been looking around at info regarding mecanum driving. I have seen you really need to use tank drive. I also found it can be done with arcade too. Except that rotating doesn't work like in tank drive. I was thinking if we used arcade drive with the logitech attack 3d extreme joystick that has a swivel joystick, would rotation then work if linked up to the swivel axis. Could this work?
Thanks
