Go to Post Our wheels just keep falling off. - SenorZ [more]
Unread 13-03-2011, 17:44
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Plastic Pneumatics Tanks / FRC1114
Having had the opportunity to check out 1114's robot at the Pittsburgh Regional this weekend, they had pneumatic tanks that appeared to be made of a plastic, and I was told they were about half the weight of the standard Clippard tanks. Anyone know where to find these, or something like them?
Thanks,
--Ryan
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 13-03-2011, 21:10
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
Team Role: Leadership
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
Re: Plastic Pneumatics Tanks / FRC1114
I'm looking into these now... They look very nice weight-wise.
Do they have the same thread sizes for KOP fittings?
Unread 15-03-2011, 20:51
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Plastic Pneumatics Tanks / FRC1114
According to he Pnueaire Tech rep, they are available in both 1/8" and 1/4" NPT. Burst pressure is rated at 500psi, and working pressure at 125 psi. A no brainer if you want, or need to, save some weight. Also relatively inexpensive, and have plastic mounting brackets available as well.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 16-03-2011, 00:52
AKA: Logan
To the teams that used these:
How did you "prove" the working pressure is rated at 125 psi to your inspectors?
Is a print-out of the specs on their website sufficient, or is there a specsheet somewhere?
Thanks!
Unread 16-03-2011, 01:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
A printout would be perfect. It lists the important information right there.
Unread 16-03-2011, 08:17
R3P0's Avatar
R3P0 R3P0 is offline
Always InTeNsE!
AKA: Jamie Robinson
FRC #1504 (Desperate Penguins)
R3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of lightR3P0 is a glorious beacon of light
Send a message via ICQ to R3P0 Send a message via AIM to R3P0 Send a message via Yahoo to R3P0
Thanks,
--Ryan
Team 33 graciously gifted 4 of them to us for our Robot "Pneuman". We will be adding 4 of these for 9 clippards.
weight .50 compared to .88 ( roughly from memory)
cu in 44 compared to 16
http://www.pneuaire.com/reca44cuin.html
We ordered the kewl standoffs for them too. I'll post pictures next week during our maintenance window.
Time is irrelevant at the speed of light.
Last edited by R3P0 : 16-03-2011 at 08:19. Reason: added link to pneuaire cylinder we are using
Unread 16-03-2011, 10:00
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Team Role: Mechanical
IKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond reputeIKE has a reputation beyond repute
No problem. You guys were so close on weight, and air is so critical to your design, it seemed like the right thing to do. One of the college students that helped found your team was a former 33 student, so we have carried a soft spot for your team for years.
Unread 16-03-2011, 10:11
R3P0's Avatar
Always InTeNsE!
AKA: Jamie Robinson
I work for Liquidweb.com and we call what you did "Heroic". Here's a Heroic salute from the work battlelines--->
http://www.youtube.com/watch?v=R0WY0xckCt4
Unread 16-03-2011, 10:43
Philip W. Philip W. is offline
Philip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to beholdPhilip W. is a splendid one to behold
Pneuaire seems to have several websites selling their reservoir cartridges (www.smcpneumatics.com, www.coastpneumatics.com, www.poweraire.com; they share the same "online support" image and similar addresses). Their other websites indicate that the RC2.5x10 is actually ~30 cubic inches. But when 8 of these tanks requires 7 minutes to fill, the difference between 30 and 44 doesn't seem like much. =P
For their full product line and their current stock, check out here: http://www.coastpneumatics.com/searc...&key word=RC2
Unread 16-03-2011, 16:25
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
It looks like 1712 just found some breathing room.
Unread 16-03-2011, 19:36
Hodge1
Rookie Year: 1996
I could be wrong, but the Clippard tank provided in the KOP is listed at 33 cu. in., making the plastic tank capacity about 25% greater. Anyone know for sure the weights of the plastic Pneuaire tank and the aluminum Clippard tank for comparison?
Just for additional consideration, in a long-term installation, I would prefer to use aluminum tanks. Plastic, over time, tends to creep and weaken, which should not be a problem on a FIRST robot.
Sweat the details
Unread 22-03-2011, 18:49
R3P0's Avatar
Always InTeNsE!
AKA: Jamie Robinson
Dateline Okemos Hs. Robot Pneuman successfully survives iron lung transplant.
Successful Lung Transplant. Weight saved Priceless!
http://www.livingsystems.net/DSC00393.JPG
http://www.livingsystems.net/DSC00394.JPG
...Breathe the pressure! ~prodigy
Unread 28-03-2011, 19:01
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
where did you get the plastic board holding all your components?
2005 - GTR WFFA
2006 - Waterloo Regional Champions with 1114 and 1503
2010 - Waterloo Rookie inspiration and Highest Rookie Seed, #2 Alliance Captain, Semi-finalists.
2011 - Waterloo Finalist thanks 1310 and 610
2014 - imagery and rookie allstar award gtr west
2014 - rookie inspiration and winners with 188 and 610 north bay
Unread 28-03-2011, 19:07
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
It looks like perfed poly from AndyMark: http://www.andymark.com/ProductDetai...ctCode=am-0836
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
  #15   Spotlight this post!
Unread 28-03-2011, 19:09
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
plastic is great for holding pneumatic pressure, or transmitting hydraulic pressure as long as it's thick enough to contain it.
for example
