Does anyone know how to attach an 3in. long axle directly to the tetrix motor, no gearbox at all?
Re: Minibot motors
Re: Minibot motors
I saw a team put shaft collars onto the remaining gear and then tinker around with that, but it kills the gear. PVC and (lots of) PVC cement? |
Re: Minibot motors
Off the shelf collars would not be legal. We made them by machining a bolt.
Re: Minibot motors
R92, S. Indicates "mechanical fasteners" are allowed. A shaft coupler/collar mechanically fastens two shafts together...there were several examples of minibots that passed inspection with such couplers/collars this weekend.
Re: Minibot motors
Pretty sure they changed that to "mechanical hardware" in an early update, might wanna check the current version manual.
Re: Minibot motors
Nope, they changed it from "mechanical hardware" because all sorts of people were getting confused. It reads "mechanical fasteners".
Re: Minibot motors
We tried this but the motors would smoke.
Re: Minibot motors
The motors will smoke because your axle is far far too large: you are not gearing correctly for the torque of the motors. It also looks like you're trying to run square shaft through a round bushing, which isn't good at all friction wise.
Round shafts through those bushings with a much smaller OD. |
#10
Re: Minibot motors
Re: Minibot motors
If the shafts are contacting more than about an inch from to the motor, there is significant wobble. If the load is more than 1.4 lbs per motor, there isn't typically enough of the shaft in contact with the pole to prevent destruction of the tire. Having the right amount of normal force on the tires is critical. The optimum is a function of the robot weight. |
#12
Re: Minibot motors
if you have extra motors laying around and money to buy more obviously they are going to burn go ahead and take the gearbox off
but a 3sec robot is possible with proper engineering it is totally up to the builder/team |
#13
Re: Minibot motors
Joe,
The correct read on R92 is S. Mechanical fasteners (e.g. screws, bolts, etc), I would be hard pressed to include COTS shaft couplers in that definition without direct GDC guidance on the subject. Something manufactured from the allowed materials would be OK. |
#14
Re: Minibot motors
Re: Minibot motors
