Go to Post Give yourself the best chance to win at the event you're at by picking the best possible alliance partners available - always. - Rich Kressly [more]
Unread 15-03-2011, 22:39
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Junit Testing?
Using Netbeans 6.9.1, latest available cRio code, etc. Trying to setup a junit test for a class of ours. Yet it says it can't find the junit library.
"package junit.framework does not exist"
Reading the Netbeans doc says junit is embedded as part of netbeans.
Is this something related to the Squawk jvm or something else? How can get junit working so I can have some unit tests.
-T
Unread 16-03-2011, 00:01
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
Re: Junit Testing?
What kind of tests are you running on the cRio that require Junit tests ?
This seems like a great idea !
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
