Tetrix Bearing Size
Does any one know the OD and ID of the Tetrix Pivot Bearings?
Re: Tetrix Bearing Size
If you are talking about the bronze bushings I believe they are 3/16 id and 5/16 od.
Bruce |
The OD is .315", the id is .115".
good luck |
Assuming you are talking about the servo bearing.
id is 3mm OD is 8mm It is about 3mm wide. It comes with a screw, nut and a couple of washers. |
Yep, the servo bearing. I just checked it quick with a set of calipers. I tried a 3mm screw but it didn't fit in the one I checked.
