Go to Post When you build a practice robot, you're literally buying time. - sanddrag [more]
Unread 16-03-2011, 09:34
tacobelldog52 tacobelldog52 is offline
tacobelldog52 is an unknown quantity at this point
Labview Crashes
When I try to launch labview it crashes with an error ( see attached )
has anyone else seen this or know how to fix it
I am running it on windows 7 64bit if that matters
Thanks!
Unread 16-03-2011, 09:41
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Labview Crashes
Here's a similar error on a different OS.
Unread 16-03-2011, 09:50
Re: Labview Crashes
Thanks for the link found out a way to get it with that link.
Here is what anyone can do with the same issue.
1. Make the user account an Administrator on the computer
or
2. Hold down shift and right click on labview, from the drop down menu select " Run as Administrator "
Thanks Again!
