Go to Post If full body suits can be made to fit properly, why do we have so many robots with saggy bumper covers? - GaryVoshol [more]
Unread 18-03-2011, 00:13
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
scheduling policy in 2011 FRC Java Framework
Does anyone know, are threads at the same priority preemptively timesliced by default? If so, what is the time quantum?
Unread 18-03-2011, 07:18
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Re: scheduling policy in 2011 FRC Java Framework
In this implementation of Java, threads of the same priority will preempt each other (so it's not a "run until completion" policy), but it is based on the number of bytecodes executed, not strictly time based.
Unread 18-03-2011, 09:21
Ether's Avatar
Rookie Year: 1969
Thanks for the reply. How do you know that? Is there a document somewhere I could read to learn more, rather than peppering you with more questions? Unless you don't mind :-)
