Go to Post I got dragged into FIRST against my will, and it was the best thing that's ever happened to me. - Liz C [more]
Unread 18-03-2011, 13:25
SoulSaber1's Avatar
SoulSaber1 SoulSaber1 is offline
AKA: Drew Parker
FRC #3011 (RoboWarriors)
Rookie Year: 2011
SoulSaber1 is an unknown quantity at this point
Bit of coding help
So, for autonamous we are using a modified line tracker code, with certain cases for different scenarios. After this loop we want the robot to go backwards, but we can't seem to make it happen.
Code:
case 7: //ALL SENSORS ON *OR* MAYBE AT CROSS
                        if (time > stopTime)
                            atCross = true;
                            speed = 0;
                            gripper.set(false);         //Closes gripper
                            gripper2.set(true);         // "     "
                            while (backCount < 5)
                                backCount++;
                                drive.arcadeDrive(-.5,0);
Any ideas?
"I don't care about what anything was DESIGNED to do, I care about what it CAN do." -Gene Kranz
"This lifestyle is DIY or GTFO" - lucid
