Re: Partial Jag failure?
Well, it worked fine today. I even held it in a 41 Amp stall for 5 seconds.
There's only two causes I can think of. One is that perhaps it had tripped the breaker and needed "voltage enable" to be sent again. However, I'm pretty sure I would have seen movement out of it before that happened. The other is that today I'm outside at 15 degrees Celcius. Friday I was inside at 30 degrees. The Jaguar only said its internal temperature was 37 degrees on Friday. I thought it would operate up to 50. (Note: I haven't opened it up yet.) |
Marshall - does it respond to PWM normally? Are there any signs of physical damage?
Al - Thank you for the very clear and informative post. The difference in total on-resistance between the Jaguar and the Victor is inconsequentially small. I think the Jag wins the numbers game, but not by enough to make an actual difference. The reason that the Jaguar uses fewer FETs is that it uses slightly more modern FETs that can handle more current per device. |
I was looking for breaker information when I found your post... You state that the MX5-A40 can deliver 133A for around 3 seconds. As I read the data sheet, 133A represents around a 300% overload, which would trip in substantially less than 3 seconds (0.5 to 1.1 seconds). Am I missing something? -Tom |
Tom,
You reading is correct. The smaller breakers have a slightly different trip spec and the 120 amp breaker is longer still. However, all of the resettable breakers will have a shorter trip spec after the first reset as the breaker is already at an elevated temperature. This is also compromised if the breaker is in a hot environment. i.e. near a hard working motor(s) or thermal shadow, adjacent breakers are also passing a lot of current or if the wiring attached to the PD has not been properly terminated (high resistance) and is creating heat from the termination. |
Texas Instruments, the designer of the part INA193, specifically calls it a 'current shunt monitor': http://focus.ti.com/lit/ds/symlink/ina193.pdf I specifically provided an official application note above in which those parts are used in a replacement function over a current sensing application...and in the last post of the series...openly noted that it could also be called a 'current sense monitor' or 'current sense amplifier'. In point of fact, other manufacturers do...indeed...use the alternative naming. For example: Here national semiconductor refers to the same basic circuit by the alternative name... http://www.national.com/analog/ampli...ent_sense_amps Here WikiPedia furthers calling this a current shunt: http://en.wikipedia.org/wiki/Shunt_%28electrical%29 "An ammeter shunt allows the measurement of current values too large to be directly measured by a particular ammeter. In this case the shunt, a manganin resistor of accurately known resistance, is placed in series with the load so that all of the current to be measured will flow through it. The voltage drop across the shunt is proportional to the current flowing through it and since its resistance is known, a millivoltmeter connected across the shunt can be scaled to directly display the current value." Wonderful world of engineering...same idea, different words...and we are all using the same language. Let's try it in Korean or Japanese. This is merely a matter of difference of terminology. This is why I posted that 3rd post. Further, you are correct...of course...it's not always the MOSFETs that go. However, it never hurts to ask because the MOSFETs have even more reasons they can go. Last edited by techhelpbb : 20-03-2011 at 12:57. |
