Go to Post My driving skills are only slightly better than my dancing skills... - RoboMom [more]
Unread 20-03-2011, 09:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
pic: One-day Minibot
Unread 20-03-2011, 09:56
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: pic: One-day Minibot
Looks Great!
Any details on the switch at the top?
JW
Unread 20-03-2011, 10:11
DonRotolo's Avatar
Back to humble
FRC #0832
It takes a whole day to reach the top? I think that might be too slow
Unread 20-03-2011, 10:22
Chris is me's Avatar
AKA: Pinecone
I'm very surprised that this minibot took 1.6 seconds to go up. My guess says it should go up in about 1.2.
Good job with the minibot. I expect this on every robot by the end of the year...
Unread 20-03-2011, 10:36
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
OMG... I started building that exact same robot yesterday.
My design had the magnets above and below the rollers as I didn't know if your configuration would provide enought vertical allignment. I even have that same top switch from Lowes.
I see that you have a limit switch to turn the bot on when it contacts the pole. I was planning to turn it on as it left the robot, but your's is probably more universally interchangable.
Too Cool.
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 20-03-2011, 10:38
AKA: Pinecone
It may be worth it to spin up the robot before you touch the pole. Play around with it and find out
Unread 20-03-2011, 10:50
jvriezen jvriezen is online now
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
One of our early minibot designs had magnets above and below drive wheels but we found that if deployment wasn't good, the bot would attach with one magnet in contact with the pole, which works very well at increasing friction and helps in the production of smoke signals. Putting the magnet between the rollers assures there is no way the magnet can touch the pole.
John Vriezen
Team 2530, "Inconceivable"
Mentor, Drive coach, Inspector
Unread 20-03-2011, 11:06
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
Team Role: Leadership
VKP is an unknown quantity at this point
What material did you use for the rollers? It looks like some sort of rubber. Did you take it off of the Tetrix wheels? Or is that electrical friction tape?
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
Unread 20-03-2011, 11:14
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
Team Role: Coach
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
He said 1.6 seconds from the base. Maybe he is referring to time it takes from breaking the plane at start of deployment to the trigger? Anyways, this looks much like our new iteration. Wonder if he left the pinion on and used set screws not visible from the front view to hold or if this is a straight press to the motor shaft. Nice work.
Unread 20-03-2011, 12:38
BIGWILLI2081's Avatar
BIGWILLI2081 BIGWILLI2081 is offline
FRC #2081 (Icarus)
Team Role: Mechanical
BIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of light
how did you connect the motor shafts to the bigger shaft?
2011 Boilermaker Regional Champions
2011 Boilermaker Motorola Quality Award
2011 Boilermaker Autodesk Excellence in Design Award
2010 Boilermaker Regional Finalists
2009 Boilermaker General Motors Industrial Design Award
2008 Boilermaker Engineering Inspiration Award
2007 Boilermaker Rookie All-Star Award
Unread 20-03-2011, 12:41
216Robochick288's Avatar
216Robochick288 216Robochick288 is offline
Hopelessly Addicted to FIRST
AKA: Abby Wilson
FRC #0216 (RobodawGs 216/288/244)
216Robochick288 is a glorious beacon of light216Robochick288 is a glorious beacon of light216Robochick288 is a glorious beacon of light216Robochick288 is a glorious beacon of light216Robochick288 is a glorious beacon of light216Robochick288 is a glorious beacon of light
Honestly, you don't even need the magnets. you could go a similar design with PVC that is just slightly bigger than the diameter of the pole then cut about 60 degrees out of it to hold to the pole with the motors under... its a brilliant design. Simple too.
216/244/288 for life
"I want you to lose [by] the most you can!" ~Mr. Hepfer at Breakaway Champs. [Curie Match 100]
RoboDawg Alumni, 2009-2012
FIRST mentor 2010-?
FLL 2010-2012,2015-2016 FRC teams 857, 2586, 5486, and 5989 2013-?
For lack of being allowed to put them up top here are all my kids!
Unread 20-03-2011, 13:07
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
can't see the battery
Unread 20-03-2011, 14:28
VKP's Avatar
VKP VKP is offline
VKP
Our team began making a minibot like this. We took the Tetrix axles and used a lathe to bore a hole in them the diameter of the motor shafts, and then press-fitted them on.
Vivek
Unread 20-03-2011, 14:54
undefined117 undefined117 is offline
FRC #0955 (Raiderbot)
undefined117 is an unknown quantity at this point
I have found that magnets make the minibot slower becuase they add friction, If you have any extra time you may want to work on getting some pvc to snap onto the pole. Our minibot can get up in 1.2-1.3 seconds.
  #15   Spotlight this post!
Unread 20-03-2011, 15:04
Nikhil Bajaj Nikhil Bajaj is offline
MATLAB Fan
FRC #0461 (Westside Boiler Invasion)
Nikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond reputeNikhil Bajaj has a reputation beyond repute
Send a message via AIM to Nikhil Bajaj
Just a note: you are correct in stating that the magnets can potentially add to the damping in the system and slow the mini-bot down. However, this is not friction, unless you are rubbing the magnets or something else on the pole.
http://en.wikipedia.org/wiki/Eddy_currents
This is a very common high school physics class demonstration, taking a vertical aluminum tube and sliding a magnet down it towards the ground. It can take longer than one would expect.
