Go to Post My guess is you all are planning on being overweight......interesting strategy.....i like it - Stephen Kowski [more]
  #16   Spotlight this post!
Unread 22-03-2011, 19:09
Pjohn1959's Avatar
Pjohn1959 Pjohn1959 is offline
AKA: Paul W. Johnson
Team Role: Teacher
Pjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond reputePjohn1959 has a reputation beyond repute
Re: 2011 Lone Star Regional
Originally Posted by LightWaves1636 View Post
We use jags cause they're more powerful than using victors. The only weakness to jaguars are metal shavings have easier access getting in.
I think you might need to check your specs again. We get faster and higher responses with the Victors.
We also found them to be a lot less durable. We have had several fail due to stress, where we have experienced nothing like that with the Victors. They just work.
  #17   Spotlight this post!
Unread 22-03-2011, 20:31
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
I'm calling BS on both sides here without some sort of verifiable data. First, the Jaguar isn't going to be terribly more "powerful" than the Victor. The FETS in the Jaguar have slightly lower on resistance, which means slightly lower power lost to heat, but it's pretty minimal and the Jag's current sense resistor probably makes the whole thing even.
Similarly, the Victor isn't going to have any quicker response than the Jaguar to a specified output voltage. They both use the same PWM rate, processing time is minimal, and I'm not going to get into whether the Jag's 15kHz chop rate would react any faster than the Victor's 120Hz chop, because you guys aren't capable of noticing that difference.
And both speed controllers are just as easy to drop metal shavings in. In case you didn't notice, the FETs on the Victor are right under that fan. The leads are exposed and just waiting for a chance aluminum shard to vaporize them.
There's only a few actual differences between the two:
1. The Victor is smaller, lighter, and more expensive.
2. The Jaguar has a more linear response curve. Meaning 20% input actually gives you 20% output. The Victors ramp up the output rather quicker than the input and then level off, so 20% input gives you something like 30% output. This may account for Paul's "quicker response".
3. The Jaguars have built in voltage rate control, which prevents you from rapidly switching between positive and negative outputs. The Grey Jaguar was likely to blow a FET driver under these conditions, which is apparently what gave the entire line a bad rep for reliability.
4. The Grey Jaguars had captive screws that were never meant to be fully removed. They left metal shavings inside the case if you DID force them to unscrew, which added to the number of failures. Which is rather more operator error than lack of robustness. Black Jaguars have fully removable screws.
5. The Jaguars have current and temperature limiting features which kick in to protect the speed controller from damage under high load conditions. The Victors will let you beat them till the breaker or the Victor blows.
And that's it until you get into the laundry list of features the Jag has that the Victor doesn't. So as far as I'm concerned the robustness of the Black Jaguar is still in the proving stage but looking good and there's little performance difference between the two aside from the linearity of the output. I think anything else is hearsay and confirmation bias unless someone's got some actual test data to back it up.
  #18   Spotlight this post!
Unread 23-03-2011, 01:18
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
THank you TI & IFI for providing options for controlling motors in FIRST. Maybe one day we will have more motor control options and more things to debate...
Getting back on topic to the people Thank Yous !
Huge thank you to Lucia , LSR was so smooth and really fast. We were out of awards at 4:30 this year !
Volunteers :
Craig for scorekeeping, J. Rogers the FTA, Kris the "MC" , Lyndon "Mr. Inspection" (notice how all of these great volunteers are NASA/Robonauts!) , and Kevin for picking up the slack , you guys are awesome year in year out and LSR would not be the same without you.
Thank you 3103/57 for setting up the rookie workshop in week 1. That made a huge difference for a handful of rookies.
Thank you to 441/2276/624/3335 for helping out with the Houston scrimmage this year ! Maybe next year we will get a few more teams
Big congrats to student leader Victor and team 441 , you amaze me every year and I wish you the best of luck in college.
118/1477/1801, great alliance and best of luck at Champs
2936 & 3320 , Miracles & DiscoZillas has a nice ring!
624/57 - leopards and green capes just works ! Hopefully it will be a recurring trend !
Last but not least !
1429 1429 1429 .... Woodie flowers, chairman's , website , qualified for VEX worlds, BEST nationals, FIRST Championship , ,....
All this success is going to dry up your piggy bank
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
  #19   Spotlight this post!
Unread 23-03-2011, 01:41
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
oops, I meant versatile not powerful, sorry haven't gotten time to wind down from Lone Star still...
FLL Team - Hackberry Hill Elementary - Arvada, CO ('08 - '10 Coach)
FRC Team 1636 - Reds Robotics - Arvada High School - Arvada, CO ('05 - '07 Alumni)
FRC Team 1583 - Rambotics - Ridgeview Academy - Watkins, CO (Volunteer/Supporter)
FRC Team 2859 - Blasterbots - CSM Robotics Outreach - Golden, CO ('09 - '10 Coach)
FRC Team 3320 - Miracles & Machines - Eastside Memorial High School - Austin, TX ('10 - '12 Mentor)
  #20   Spotlight this post!
Unread 24-03-2011, 19:19
I-DOG's Avatar
I-DOG I-DOG is offline
Texas Tourist
AKA: Austin Vaughn
FRC #0624 (CRyptonite)
I-DOG is a splendid one to beholdI-DOG is a splendid one to beholdI-DOG is a splendid one to beholdI-DOG is a splendid one to beholdI-DOG is a splendid one to beholdI-DOG is a splendid one to beholdI-DOG is a splendid one to behold
Talking Re: 2011 Lone Star Regional
Congrats to 1477, 118 and 1801 for their 2011 lonestar win!
Thanks 57 and 1817 for the great run our alliance had with one another!
Awesome job 2936 and 2587! You guys sure gave the number 1 seed alliance a run for their money!
Thank you gatorzillas for combining forces with some of the 624 members in order to help out 3758.
And why is their never an archive for Lonestar's matches?
Team 624 loans their green capes to their alliance partners during Eliminations.
Are you going green this competition season?
These teams did: 118, 233, 987, 1477, 1902, 3008, 3015, 3476, 3997
CRyptonite 624 - 2008-2011: Student
CRyptonite 624 - 2012-2014: Scouting & Pit Outreach Mentor
RoboRaiders 1817 - 2011-2012, 2014: Strategist & Scouting Mentor
The Outlaws 4717 - 2013-2014: Mentor
  #21   Spotlight this post!
Unread 24-03-2011, 21:58
RoboCat2005 RoboCat2005 is offline
AKA: Catlin Level
FRC #3659 (Mighty Patriots)
RoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to allRoboCat2005 is a name known to all
Thank you to team 57 and their 2 mentors who helped out 2969 with our drive train issues. It was a big help and the kids really appreciated it. Ended up being something as simple as doubled up omni wheels that was causing the issue.
Thank you again
FRC team 2969 Sam Houston High School - Hurricane Robotics
  #22   Spotlight this post!
Unread 24-03-2011, 23:38
MrHance's Avatar
MrHance MrHance is offline
Long Distance Mentor
FRC #0647 (Cyber Wolf Corp)
MrHance has a spectacular aura aboutMrHance has a spectacular aura aboutMrHance has a spectacular aura about
Lightbulb Re: 2011 Lone Star Regional
Based on the above information, I also believe it depends on the application of the device. It would be interesting to see if a team or a group of teams would test the JAGs and Victors under similar conditions and collect data to be posted on CD as a white paper for all to reference for future use. Let's not favor on device over another unless it can be backed up with data. This is how engineers determine which device should be use over another, not by individual gut feeling. This could cause issue as was seen in the past without data to back up claims of problems. Think about it.
