Go to Post You just have to care enough to give it a try. Your mentors will appreciate the effort. - Koko Ed [more]
Unread 21-03-2011, 23:04
LiquidMagik LiquidMagik is offline
FRC #0649
LiquidMagik is an unknown quantity at this point
Is it legal to use foam filled pvc on the minibot?
Thank You.
Unread 21-03-2011, 23:17
VKP's Avatar
VKP VKP is offline
VKP
AKA: Vivek Paramasivam
FRC #1899 (Saints Robotics)
Team Role: Leadership
VKP is an unknown quantity at this point
Re: Is it legal to use foam filled pvc on the minibot?
I would assume that the foam is illegal. THe list of parts you are allowed to use are specifically outlined in the rules. If it's not named in that list, you cannot use it =\
Vivek
Treasurer, Senior Build Officer, Saints Robotics 1899
Seattle Olympic Regional Chairman's Award 2011
Seattle Olympic Regional Winner 2011 (Thanks 2990 & 3393)
Seattle Olympic Regional Best Website Award 2011
Unread 21-03-2011, 23:25
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Can you provide an example of the part you have in mind?
There is black foam core ABS plastic pipe, is that what you mean? if so, it's ABS, not PVC, and as far as I can tell it's not on the list of approved materials.
Unread 21-03-2011, 23:32
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Well, polycarbonate foam should be fine, and if you melt down allowable materials and make that into foam that is technically ok as well. Pre-filled pvc is probably illegal.
Unread 22-03-2011, 01:04
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
What about if the plan is to use it as a non-functional decoration?
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 22-03-2011, 01:54
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Sure, if it's aluminum foam sold as a sheet. (I bet the GDC didn't see that coming ....)
Or if these guys are your sponsor, just have them cast the metal foam into an appropriate size for you to insert it, being sure to begin with a crucible of melted-down legal stock. (Until the GDC comes right out and specifies limits for modifying otherwise-unrestricted <R92> items, casting whatever you want out of aluminum—or fasteners for that matter—continues to be a viable option for the minibot. It's just like the days when the Small Parts catalogue was the only legal source for most robot components.)
Unread 22-03-2011, 02:53
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
If you're talking about expanded PVC sheet (also known as PVC foam), then no.
If it's sold as PVC or CPVC pipe or fittings, then yes.
I believe non-functional decorations may be from any material though, not limited to those on the approved materials list.
Unread 22-03-2011, 03:27
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
If it is non-functional, then why foam filled at all? just use PVC pipe.
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 22-03-2011, 08:33
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
I believe the OP was talking about foam-cored PVC pipe, which I cannot remember the name of right now. I would assume from the GDC's previous rulings (limit switches for one), that if it is marketed as "PVC Pipe", then it is probably legal, you just have to prove that it is marketed as PVC with a receipt or something.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2012 Wisconsin Regional Engineering Inspiration Award
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
Unread 22-03-2011, 18:35
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Is the foam intended as a bumper for hitting the top or bottom of the tower?
Team 241 experimented with 1/16" thick latex surgical tubing and a hand air pump...
I felt sort of naked making animal balloons without clown makeup on.
In addition to making students smile, the balloons can also provide cushion without adding much weight to the robot.
Unread 23-03-2011, 10:29
clayman's Avatar
clayman clayman is offline
AKA: Clayton
FRC #3175 (Knight Vision)
Rookie Year: 2010
clayman is an unknown quantity at this point
I don't know if this fits into the rules, but you can buy solid PVC rod from McMaster-Carr.
Unread 23-03-2011, 23:01
AKA: Alan Wells
FRC #1350 (Rambots)
Nope, only pipes and fittings.
