Go to Post Its great for us as mentors to see students teaching other students and a robot being built from scratch without us. Maybe someday they won't need us at all!!! - DR3381 [more]
Unread 24-03-2011, 18:33
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Minibot switches and soft landings
That should be legal.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 25-03-2011, 22:20
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
@Brando
Hm, I guess I was misreading rule G22 as not being able to contact the hostbot after any part crosses the deployment line, and not as long as any part is over the deployment line. In that case, I don't know what our partner's red card was given for during that match, we just assumed it was a G22 violation.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
Unread 26-03-2011, 08:15
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
Originally Posted by Vermeulen View Post
@Brando
If a deployer swings the minibot down, like a drawbridge, and as it comes down if any portion of the minibot is above the deployment line and simultaneously within the vertical cylinder of the tower and in contact with the deployer- independent of whether it is in contact with the pole, I think the referees will rule it in violation.
Here's a whole thread on it...
http://www.chiefdelphi.com/forums/sh...ent+cylind er
Unread 10-04-2011, 00:18
11douglash 11douglash is offline
FRC #1072
11douglash is infamous around these parts11douglash is infamous around these parts
What we did is find a 4 way light switch (i believe). Basically, it was a switch that flipped polarities. Then there was another switch that triggered when the robot hit the pole.
Our minibot went up, flipped the polarity switching switch, powered down, hit the bottom, and then, due to the mechanical way the wheels were rotating, fell off, and thus broke the switch that kept it powered, and turned off.
Unread 10-04-2011, 03:19
penguinfrk's Avatar
penguinfrk penguinfrk is offline
AKA: Larry
FRC #1899 (Saints Robotics)
Team Role: Leadership
penguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of light
This was the circuit diagram for our minibot.
Name:	Minibot Circuit Diagram.jpg
When we short the motors, the current generated when backdriving will go through the circuit again the opposite direction. The result is a fairly slow terminal velocity when it falls.
Hope that helped.
Larry
Saints Robotics 1899
High school intern at FIRSTWA
2011 Seattle Olympic Regional:
Website Excellence, FIRST Dean's List Award (for team captain Kevin Kimura), Tournament Winner (Thanks 3393 and 2990!), Chairman's Award Winner
Unread 22-03-2011, 21:22
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by WarehouseCrew View Post
What specific electrical switch is working to turn the minibot off after the top pole sensor is successfully tripped (but not turning off without triggering sensor)?
I saw team 75's minobot with a KoP microswitch limit switch, where they bent the lever into a "C" or 'hook' shape so when it is pressed down, it 'latches' under the body of the switch and keeps the switch "off". Since it's a SPDT switch, they use the NO contact to short out the motors as described above.
Unread 10-04-2011, 23:44
sumginazu sumginazu is offline
FRC #1351
sumginazu is an unknown quantity at this point
I did the same thing with a simple momentary switch when designing the minibot my team used. The latch worked perfectly, but we had to be careful in ensuring that the switch consistently contacted the top plate - it didn't during one practice run, which ended with a burnt out motor.
Our minibot usually stayed at the top after it had finished its run because it did not weigh enough to backdrive the motors, which ended up being okay. Unfortunately, the minibot's momentum occasionally caused it to fall off the pole once it hit the top plate, and twice it hit the ground hard at the end of a match. We needed to repair it both times. As long as your minibot has a reliable method of attaching to the pole and it does not "free fall" after it hits the top, it should survive a trip back down. You should certainly test it to make sure, though.
Unread 27-03-2011, 18:43
waitwhat?'s Avatar
waitwhat? waitwhat? is offline
Driver Coach
AKA: Bunca
FRC #0747 (Flight Crew)
Team Role: Coach
waitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant future
Talking Re: Minibot switches and soft landings
I have two questions that I would appreciate help with. What specific electrical switch is working to turn the minibot off after the top pole sensor is successfully tripped (but not turning off without triggering sensor)? We have one push button switch from Home Depot that takes about 7 pounds of pressure to turn it off. The fuse may trip before this works.
Secondly, how do you make the minibot come down the pole to a "soft landing"? I've read that some teams are using reduced power on the motors to provide a braking action after the top sensors is reached. How is that done (eg. my switches are only on and off, no 1/2 power option) and is there a risk of burning up the motors?
Thanks.
Here is a little tip. McMaster Carr sells "Manual Reset limit switch" Part # 7336K51. Works like a charm. This will also allow you to create this circuit with EASE.
This is exactly how our minibot is wired....
Unread 30-03-2011, 16:43
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
Is that considered a legal switch according to the rules and all the Q&A?
Please don't call me Mr. Ed, I am not a talking horse.
Unread 30-03-2011, 16:54
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Yep, it is marketed as a "limit switch" so it is allowed.
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Yes it is. The McMaster catalog lists it as a "limit switch" and it is the application for which it is most used.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 30-03-2011, 20:26
TheCommander TheCommander is offline
FRC #3125
TheCommander is an unknown quantity at this point
We did something a little different.
I took the Tetrix switch that is legal, took out the dremel, put on a cutting wheel and removed the on half of the toggle so that it is flush when the switch is in the off position. Now it only toggles to the off side, but can be reset to the on position.
We mounted the switch at the top of the mini-bot and when it hits the trigger it toggles and turns off the mini-bot. It can be mounted by cutting out a rectangle that is 1 inch by 1/2 inch and pressing the switch in. We designed the mini-bot a little more on the rugged side, so when gravity pulls it back down the pole it can withstand the impact.
The added bonus is that it mounts easily, is sturdy, looks nice, and the red on the switch lets you know the mini-bot is armed.
This just seemed like the simplest solution for our design and application.
Unread 04-04-2011, 17:25
krudeboy51's Avatar
krudeboy51 krudeboy51 is offline
Only Programmer
AKA: kory
FRC #0369 (369)
Rookie Year: 2010
krudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of lightkrudeboy51 is a glorious beacon of light
Send a message via AIM to krudeboy51
wouldn't the highlighted area on this pic cause the fuse to blow?
