Go to Post Every team should have a rule about not shouting "ROBOT!" when transporting a robot around the pits/arena. - frasnow [more]
Unread 23-03-2011, 13:14
niteowl22 niteowl22 is offline
co-advisor, team 1091
AKA: Anne
FRC #1091 (Oriole Assault)
Team Role: Communications
niteowl22 is an unknown quantity at this point
Question Mini bot fuse question
What I need to know, is what size fuse, that the mini-bot battery pack uses, and where to purchase them.
Thanks in advance for answers!
Unread 23-03-2011, 13:23
Amehrotra Amehrotra is offline
FRC #0503 (Frog Force)
Team Role: Mechanical
Rookie Year: 2007
Amehrotra is an unknown quantity at this point
Re: Mini bot fuse question
Im pretty sure the fuse type is called mini blade fuse
The fuse in the stock battery uses a 20AMP fuse, Since the motors stall current is around 7 amps I would recommend putting a 5 amp fuse in there.
This way the fuse will blow before the motors blow, just be sure to have extra fuses in hand.
The Wikipedia of the Future:
http://froggypedia.com/
Team 503 FrogForce
Unread 23-03-2011, 17:20
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Unless you are using 2 motors, in which case you probably want to go with a 10 amp fuse since together they will draw 7 amps at full power (14 at stall)
Close enough to taste it, too far to reach it
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
We got ours at the local RadioShack: http://www.radioshack.com/product/in...ductId=2102772
They're just called mini-blade fuses.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 23-03-2011, 13:26
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
You can also get the fuses from any place like Autozone, Napa, Advanced Auto.
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
Unread 23-03-2011, 13:28
AKA: Anne
Thank you!!! I knew this was the right place to ask for a quick answer. You people are great!!
Unread 23-03-2011, 13:35
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Rookie Year: 2007
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
these are also commonly refered to as an ATM sized fuse.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 23-03-2011, 16:06
Tuba4 Tuba4 is offline
AKA: Tom Albert
FRC #0063 (The Red Barons)
Tuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant futureTuba4 has a brilliant future
Got a nice assortment box at our local Walmart with sizes from 2 amp up to 25 amp. Heavy on 7.5, 10, 15 and 20 amp sizes. Under $20.
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
With a direct-drive minibot, I was blowing 5-amp fuses. 10 Amp works but makes me nervous. Maybe there's a 7 Amp fuse.
Unread 23-03-2011, 17:30
How many climbs/matches did yours last with the 5amp?
Unread 23-03-2011, 17:33
For OUR tests, we lasted about 6 inches of vertical travel before the 5 amps popped. When our minibot deploys and hits the bar, the spinning shaft gets slowed down considerably and theres a definite current spike that occurs to get the bot moving.
We switched to 10 amps, been using the same one all competition. Our turn off switch is EXTREMELY reliable so we are less concerned about smoking anything with our system, so 10 amps may be overkill for your needs.
-Brando
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
We used 5 amps for a bit, went through a fuse a match pretty much.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 23-03-2011, 21:45
DonRotolo's Avatar
Back to humble
FRC #0832
A team in NJ was using the 7.5A fuse as a shut-off for when it hit the top, I didn't notice any damaged motors. They did blow a fuse every match though.
Unread 23-03-2011, 21:58
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
We use a 7.5 A, and replace it after every match.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
  #15   Spotlight this post!
Unread 23-03-2011, 22:38
Team Role: Teacher
It immediately blew. Would not even start moving.
