Go to Post Figure out where you have to start and what end result you want, from there, all you have to fill in is the middle. - Beth Sweet [more]
Unread 23-03-2011, 21:14
siggy2xc siggy2xc is offline
AKA: Tyler Siegrist
FRC #1756 (Argos)
siggy2xc is an unknown quantity at this point
using a custom vi multiple times
I made a vi that will turn a boolean that switches on press to a boolean that will latch on press. I used this vi probably about 6 times in something I coded, it is no longer working because it is probably reading all the inputs at the same time. How can I make it work like one of the vi's from the functions panel?
Unread 23-03-2011, 21:27
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: using a custom vi multiple times
You need to set it to be re-entrant in the vi properties
Unread 23-03-2011, 21:41
AKA: Tyler Siegrist
FRC #1756 (Argos)
Thank you so much
