Go to Post ... it's us against all the bad-grammar-usin', "ya know"-slingin', graciously excepting, "congradulations"-totin', "nu kU ler"-spoutin' linguistic Luddites out there. We'll see who wins! :D - dlavery [more]
  #16   Spotlight this post!
Unread 25-03-2011, 13:17
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
mwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond repute
Re: Graph of ETCs, EMCs, and ERCs through week 3
Originally Posted by speedbuggy76 View Post
How do you know which team has the most minibot points per match to make this assignment if all previous assignments were done similarly (using past results to make the assignment). How do you make the initial assignment (a team's first minibot deployment), if they have no past data to base an assignment on? It seems to me like a self-fulfilling prophecy where if you score a first place minibot in each of your first couple tries, you will receive first-place credit for any future situations where combined points have to be split between two teams.
Also, I assume you're including all regional data for these results and not just the most recent regional for each teaim?
Let me know if I'm misunderstanding this.
As a match gets added the contributions for all matches are recalculated. So at first you are right. But come Saturday there should be reasonable numbers for each team.
There are some downfall to.the system though. Some teams will.steal mini points just by having the luck of the draw.
All calculations are based off the latest regional as that the true judge of a teams current state.
The way it winds uo working is every team has a running mini score. So the higher your running score the more credit you get. It's far from perfect but seems to work well enogh.
"Never let your schooling interfere with your education" -Mark Twain
