Go to Post I hope that 50 years from now, FIRST is no longer required. - Lil' Lavery [more]
Unread 23-10-2001, 16:32
punky2k1 punky2k1 is offline
punky2k1 is an unknown quantity at this point
Send a message via AIM to punky2k1
"Surgical Tubing"
Is there a limit on the rubber surgical tubing that we can use? We are planning on using it as springs and it does not say that there is a limit on the amount of springs that we can use.
Unread 24-10-2001, 14:57
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
No for now...
I am going to say no unless there is a compelling case to make this change.
The fact that you are using it as a spring does not really qualify it as a spring for the purposes of additional materials.
Sorry.
If you have a case to make, let me hear it. I may be convinced if you have a good argument.
Joe J.
