Go to Post Remember, WWGD? (What would Grandma Do?) - Vikesrock [more]
Unread 25-03-2011, 13:38
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
Rookie Year: 2007
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
pic: Twisted Hex Shaft
Unread 25-03-2011, 13:50
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: pic: Twisted Hex Shaft
Impressive. A harsh reminder of the kind of force that FRC bots exert.
Unread 25-03-2011, 13:54
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
3/8" diameter, 2024 aluminum?
I'm curious to know just how much torque that took...
In 2008, our arm was able to rotate the keyway of a piece of hardened 1/2" steel keyshaft almost 90 degrees. It's impressive how an FRC robot can destroy itself!
Unread 25-03-2011, 14:14
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
waht kind of aluminum is the turnbuckle?
Unread 25-03-2011, 16:25
rahilm's Avatar
AKA: Rahil Mehta
Rookie Year: 2007
1/2" 7075, which is why we were pretty surprised.
Not sure the alloy, but it was some small diameter (bad idea in hindsight)
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 25-03-2011, 16:31
Andrew Y.'s Avatar
FunYun
AKA: Andrew Yun
FRC #2415
gotcha 7075 was the number iw as looking for. Just to be nosey it wasnt 7075 -0 right?
Unread 25-03-2011, 16:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I've never seen Al hex in anything other than T6
2001-2004: Team 100
2006-Present: Team 254
Unread 25-03-2011, 16:56
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Wow, that is quite a failure for a 1/2" 7075 shaft. Can you explain in a bit more detail the application this was in under failure?
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 25-03-2011, 16:58
Andrew Y.'s Avatar
FunYun
AKA: Andrew Yun
FRC #2415
never seen dosent mean never exists.
most common types of 7075 is 0, T6, and T631. Although there are MANY different types such as T7362 is also a common one.
Unread 25-03-2011, 17:07
rahilm's Avatar
AKA: Rahil Mehta
Rookie Year: 2007
T7351 Actually.
It was on our arm. Basically we have 2 Banebot's gearboxes with chain running up to the arm. We have approx. 50 lb-ft of torque (don't worry, 1:4 chain reduction, only 6.25 lb-ft on each gearbox). We have chain on either side of the arm, and we decided to change the tensioning method to turnbuckles. Almost immediately as we raised the arm, the turnbuckle one side (the twisted side failed) while the other one held. The torque of the arm in addition to tension being held by the chain all released in one instant twisting the shaft, as the tension still held on the other side (on which the gearbox's rollpins sheared)
Unread 25-03-2011, 17:24
Andrew Y.'s Avatar
FunYun
AKA: Andrew Yun
FRC #2415
Originally Posted by rahilm View Post
T7351 Actually.
thanks for the assist...my brains all scrambled this morning
Unread 27-03-2011, 17:10
sometimestommy's Avatar
sometimestommy sometimestommy is offline
Schrödinger's Assistant
AKA: Thomas Moll
FRC #1939 (Ku-Nig-Its)
sometimestommy is on a distinguished road
Whew! thought that was a lead screw
Unread 28-03-2011, 04:57
ligiahag7902 ligiahag7902 is offline
Junior Member
ligiahag7902 is an unknown quantity at this point
I also think so.
