Go to Post There's nothing wrong with taking suggestions but be sure not to let other people tell you how your team should be run. - NickE [more]
Unread 27-03-2011, 14:11
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Wire preference - stranded or solid
Al,
Excellent point made on stranded wire compression at a terminal connection.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 27-03-2011, 18:36
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
There is no reason to use solid core for any of the "large wires" i.e. 22 AWG or larger, but it's fairly common to see some of the bundled data wires (RJ12 telephone cable for CAN bus or ethernet cabling) using solid core rather than stranded. I'd still prefer to use stranded for these applications but IMHO it's less critical.
