Wireless in pits
I know the rules say that we cant have wireless signals in the pits but I have a question.
Can I set up a router in my pit to help my iPad remotely connect to my laptop for scouting, or no? I was planning on having it a protected wireless. The reason for doing this is because my laptop doesn't have the best battery and the scouting program i have isnt an app. Or does anyone know of any programs like teamviewer that uses bluetooth instead of wireless internet? |
Re: Wireless in pits
No.
dang that is what i thought
anyone know if there is power outlets in the stands at the Williams regional in Minnesota? |
in general, most events do not promise/have power in the stands. especially if they are permanent stadium-style, mostly because there is no reason to have them there normally. (people wouldn't usually need power in the stands.)
so, i wouldn't count on it |
I would get a dc to ac adapter for a FIRST battery to use it for an outlet in the stands.
we have an inverter does anyone know how well they work?
and dose anyone know how to remotely control a computer with Bluetooth?
Williams arena and the sports pavilion are fairly well covered in University of Minnesota Wi-fi which does have guest access, it is just a matter of whether or not it will interfere with the FRC control system and get turned off (though this did not occur last year) so there is a chance it will still be on. I am doubtful but it may be possible for you to connect through that network but I have a feeling both your Laptop and iPad would have to be connected to the same access point. As for setting up your own wifi network, besides it being illegal, there is about a 1% chance you could receive a wireless signal from the sports pavilion (the pits) at Williams arena (the field) As for bluetooth wouldn't you have the same issue of running out of battery since bluetooth has a range of 30 feet or so. If you want I can try to use a remote mouse program over wifi at the university of Minnesota (deliberately connecting to different wifi hotspots) with my phone sometime this week and see if it works. Last edited by Trent B : 26-03-2011 at 19:48. |
thanks cause i found this program on cheifdelphi but its only for computers...
so my hope was to have my laptop charging at the pits and connected to the wifi and my ipad in the stands also connecting to wifi controlling it remotely via team viewer. |
#10
You may have issues with the U of M network as I am not sure how locked down the ports are. So if teamviewer goes out of the network to a central server then back in you may run into issues. If you can find something similar made for local networks you could have better results potentially.
#11
Along with wireless networks, I believe bluetooth has to be off as well.
In the game manual they ask for NXT's with bluetooth disabled for minibots, so if they ask bluetooth to be disabled for minibots, I don't think they'd want it enabled on your iPad either. |
#12
I thought they wanted BlueTooth disabled on the NXT because BlueTooth was allowed in other parts of the arena and they wanted to ensure that there would be no communication with the minibots from the stands. I haven't seen them asking people to remove their ear pieces which BlueTooth to the cell phone.
#13
If I remember correctly the FMS system uses 5ghz wifi for control so that wouldn't make bluetooth a problem (being 2.4 ghz) but could make other 5ghz wifi networks cause issues.
#14
There is no restriction on bluetooth. Just Wifi.
#15
The issue at hand for regionals hosted at colleges and universities this year has been the number of access points. The more there are the more trouble there is for robots connecting to the field. There were serious issues up at Finger Lakes and serious issues at the Florida regional. For both regionals, Thursday's practice matches were a mess and on hold for an upwards of 4 to 6 hours. (Florida was at least 10 to 2 or 3). Please follow the Wi-Fi rules and don't create a problem, I thank you in advance!
Cass |
