Go to Post Robot teams will expand to fill the available space. - topgun [more]
Unread 26-03-2011, 19:34
scienceguy22 scienceguy22 is offline
FRC #3641 (The Flying Toasters)
Rookie Year: 2011
scienceguy22 is an unknown quantity at this point
Deploying Code Shortcut
Isn't it a hassle having to redeploy code every time you make a change, well I can't fix that, but I can make it take less than half a minute. Inside every cRIO module there is a fpt server. fpt stands for file transfer protocol, and you can use this to your advantage. Using the fpt server allows you to directly place your robot's start up code directly into the cRIO device. Before you do this, however, you will need two things, a hard wired connection to port 1 of the cRIO along with the location of your built code, and yes you still have to build your code.
The first thing that you will do is open the command prompt. Type fpt 10.xx.yy.2 (xxyy being your team's number), then press enter, and this will establish a connection to the fpt server. The command prompt will then tell you that you need a username, it is anonymous, after that a password, there isn't one so just press enter. Now you have access to the files inside your cRIO. Then type cd ni-rt and press enter, to open the directory housing your real time code, (if at any time you would like to see the list of files type dir). After that it will give you a line saying you're in directory /ni-rt/. This means you're doing it right. Then type cd startup and press enter. It will again tell you you're in directory /ni-rt/startup/. Now type put and the path to you're built startup code (most often it resembles C:\...\builds\c\ni-rt\startup\startup.rtexe). The command prompt will display a message saying that it has established a connection and is transferring data, start up code already exists at this location but the actions you are performing overwrite that code. If you did it right then it will tell you so, and most often this process takes a couple seconds. When finished type close and the command prompt will "Thank you for using National Instruments". Close out of the command prompt and restart your robot, your start up code will pop up and after a couple of times of doing this you'll have it so that minutes of deploying will turn into about 10 or 15 seconds.
