Re: Deploying Code Shortcut
HTH |
The second IP port is normally configured to 192.168.0.xxx. It can be changed via Max, but I suspect that the imaging tool will put it back. I'm not sure if an ftp server is active on the port. I suspect it can be configured if needed.
Greg McKaskle |
HTH |
ah that makes since, quick question how do you access the console on the robot?
Thanks for posting - you were a great team to work with this weekend at the Ann Arbor regional. We will definitely look into using this or a similar protocol for deploying code. Good luck in your future endeavors! GO FIRST!
~Beth |
I don't really get it. Building the code takes longer than deploying does, and deploying is much more useful in terms of debugging.
Several other things: I'd assume (or at least hope) that all teams know how to do this or something equivalent already, or else they wouldn't be able to compete. There's no reason to hard-wire the C-RIO to do this, unless you want the downloading time of two or three seconds to be improved. Doesn't the "run as startup" option in labview do the same thing? Windows Explorer is also an ftp server... just go to the address bar and type in "ftp://10.xx.yy.2" I never thought about making a batch file though -- that sounds like a great idea. |
FTFY. Also, Windows Explorer lacks many of the features a client such as FileZilla offer. |
Our team has actually set up a sweet system for autonomous that concurs the task of not having to deploy code.
Our autonomous code actually parses an text file found on the robot that we transfer using FTP. This makes for a quick and easy way to change autonomous' and helps to avoid touching or changing code on the robot, that might affect our teleop code. We determined we can change our autonomous code from one to another in 11 seconds. |
