Go to Post Are we really that close-minded that we have to insult other teams that deviate from what we percieve to be right? Giving an opinion and insulting someone are far from each other. - Amanda Morrison [more]
  #46   Spotlight this post!
Unread 10-04-2011, 18:19
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Re: High torque that can be purchased.
I am just throwing this out there, but my team used cable to actuate the arm on our elevator. The idea is based on how cables are used on weight lifting machines to translate rotational motion into linear "lifting", we just do the inverse in our system.
We found it simple and relatively easy to set up with minimal precision work (my team uses a bandsaw and a drill press only). It is nice because you can basically have as much torque as you want by just changing the point where the cable attaches to the arm and/or the position where the cable "pulls the arm from". With cable you can either power the up direction only, down direction only, or power both.
It may not be ideal for the arms of the length you are talking about but it is an easy to implement and reasonably effective solution.
I have included a picture that shows what we did. It was implemented at the last minute so it was not at all refined, but it was quite effective. I don't know if this is useful, I just thought I would throw it out there.
Name:	Arm Cable Mechanism.jpg
ID:	10553  Click image for larger version
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
  #47   Spotlight this post!
Unread 11-04-2011, 08:49
qnetjoe qnetjoe is offline
AKA: Joe Daily
qnetjoe is on a distinguished road
Send a message via AIM to qnetjoe Send a message via MSN to qnetjoe Send a message via Yahoo to qnetjoe
Our team used a two RS-775s with Cim-u-lators and a 64:1 P80. This was connected with 10:1 (12:120) final sprocket drive and worked great.
In the off-season season we will work with some gas struts and perhaps some springs, so we can increase the speed of our arm.
For reference you can see a pic of our bot here:
http://www.chiefdelphi.com/forums/sh...highlight=3320
  #48   Spotlight this post!
Unread 12-04-2011, 12:53
AlDee AlDee is offline
FRC #1099
AlDee is an unknown quantity at this point
Originally Posted by Billfred View Post
We used two window motors ganged together by a shaft with a (I -think-) 10:60 chain reduction. Combined with some surgical tubing counterbalancing, we've never been wanting for torque or speed on our arm ).
We did essentially the same. I read that some teams were having difficulty with Jaguars putting out unequal outputs and damaging the motors. We didn't have that problem. Perhaps because we used Victors. The only difficulty we had was adding enough counterbalance to prevent gravity from slamming the arm down.
  #49   Spotlight this post!
Unread 12-04-2011, 13:23
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
That puts max power of the 775's at around 61 degrees/second rotation of your arm. That's certainly about where you want it. And the 120:12 sprocket reduces the torque on the P80 by a factor of 10. Nice design.
  #50   Spotlight this post!
Unread 12-04-2011, 17:00
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
We did the same thing with only a 9:1 reduction and we used Jaguars. The arm worked fine because of the counter-balancing.
  #51   Spotlight this post!
Unread 12-04-2011, 17:04
Ether's Avatar
Rookie Year: 1969
Just curious where you read this.
