Go to Post I jumped up and yelled when I saw both my teams in the same division. Less running for me in the pits. Thank you, Great Homie in the Sky! - Barry Bonzack [more]
Unread 27-03-2011, 15:07
Jeff L Jeff L is offline
FRC #0174
Jeff L is an unknown quantity at this point
Aluminum Pneumatic Fittings
Our team would like to make new Pneumatic connectors out of aluminum rather than having the Brass fittings from the kit for weight. Now, I've looked in the rules, and at R66, I'd like some clarification on whether or not we could do this, I've seen people with custom PVC storage tanks so I know you can make your own pneumatic parts to an extent. Any clarification would be appreciated.
Unread 27-03-2011, 15:14
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Aluminum Pneumatic Fittings
If they have custom PVC storage tanks on their competition robots, the inspectors should have stopped the inspection on the spot. PVC isn't safe for air storage, and those tanks almost certainly aren't COTS. If it's plastic and COTS with appropriate ratings, that's another thing altogether--it fits the requirements.
<R65> To satisfy multiple constraints associated with safety, consistency, robot inspection, and constructive innovation, no pneumatic parts other than those explicitly permitted by the Pneumatic System Rules may be used on the ROBOT.
<R66> In addition to the items included in the KOP, pneumatic system items specifically permitted on 2011 FRC ROBOTS include the following items. All included items must be “off the shelf” COTS pneumatic devices rated by their manufacturers for working pressure of at least 125psi and used in their original, unaltered condition (except as required for assembly with other components).
Now, on to your question. If it isn't a COTS pneumatic device with appropriate ratings, don't use it. But if you can find a COTS source, and can get the parts in time, go for it (just make sure you have what you need to show that it's COTS if asked).
You may also want to take a quick look at <R67-B>, which spells out allowed modifications to existing parts (of which there aren't a whole lot).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 27-03-2011, 15:17
ROBOTS!'s Avatar
ROBOTS! ROBOTS! is offline
Minibot Master
AKA: Ian M.
FRC #1504 (Desperate Penguins)
Rookie Year: 2011
ROBOTS! is an unknown quantity at this point
Do you mean storage tanks like these?
http://www.pneuaire.com/reca44cuin.html
These are a great way to cut down on weight! we took off around 5 lbs from our robot this year from switching to these. R3P0 from 1504 put the specs as far as he could remember on here
weight .50 compared to .88 ( roughly from memory)
cu in 44 compared to 16
Unread 27-03-2011, 15:23
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Also I believe mcmaster sells aluminum fittings. They are available. We are running them where we can.
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Jeff,
No. Absolutely, definitely not:
The "custom PVC storage" you speak of are COTS and rated for 125 PSI (500 PSI burst).
Making custom pneumatic components can be dangerous to you, your team, visitors in the pits, field personnel and spectators in the stands.
Please do not attempt this...
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 27-03-2011, 15:26
DonRotolo's Avatar
Back to humble
FRC #0832
<snip>
You absolutely positively cannot make your own pneumatic parts.
Unread 27-03-2011, 18:20
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Mcmaster-Carr has a full variety of aluminum pipe fittings that can replace any of the brass fittings in the KOP. The catalog page documents that the fittings are rated for 125psi, so print the catalog page and take it with you to inspection to show that they are in compliance.
