Go to Post [You know you've overdosed on FIRST when...] When you discover that the cure to the swine flu is "oink oink BOOM!" - Katie_UPS [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 28-03-2011, 22:47
Kai Williams's Avatar
Kai Williams Kai Williams is offline
FRC #4944 (Hi Fives)
Team Role: Leadership
Kai Williams is an unknown quantity at this point
Autodesk Inventor 2011 help
To design the robot this year, I am using Autodesk Inventor 2011 Pro *Student Edition*. I am trying to enter a manual density for a sheet of aluminum honeycomb material (6 kg per cubic meter) and I can't seem to figure it out.
All of the forums tell me that I should be able to go into iProperties and, under the "Physical" tab, manually override the density value, but this never seems to work. Nothing happens when I click on the dialog box and try to enter a new value.
I am using the FIRST Robotics student edition of Autodesk, available for download here.
Any suggestions?
Let 'er rip, Tater Chip!
Unread 28-03-2011, 22:54
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Re: Autodesk Inventor 2011 help
Just set the material properties to be aluminum 6061. It might not be the same type of aluminum but its pretty close.
Or calculate the expected mass using the volume and override the mass instead of the density.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 28-03-2011, 23:11
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
First, you may find it easier to find your density in g/cm^3 (or lb/in^3, whatever you're working in).
Second, the easiest way I've found of doing this, though jank, is to edit the mass until the density is adjusted to where you want it to be. It sounds like you're in the right menu, just edit the mass instead of the density, because density is probably in a gray box.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 29-03-2011, 01:46
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
If you have time, make the honeycomb material using a pattern. It takes a little practice, but its a good exercise and its not that difficult. It also makes for a really cool looking drawing.
But if you wanted to just go to the iproperties and change the material properties, its been awhile since I have done it (I have been using Solidworks lately) but I remember just typing in the density to get the correct weight. but its been a long time since I have done anything like that.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 29-03-2011, 21:14
Thanks guys. I've noticed all of these fixes, but I was hoping for a direct method of manipulating the density, but it seems that there is no way to do it without spending around $5,000 for the full version...
Creator Mat, thats pretty much what I have it as right now, but a solid block of aluminum that size weighs a LOT more than the honeycomb material (I actually have a sheet of the stuff at school, but that's an hour's drive away).
If I have the time, I will probably just end up making a hexagonal pattern and sandwich it between two sheets of aluminum. If not, I'll just manually override the weight to something close.
Thanks!
Unread 29-03-2011, 21:18
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
I don't think there are any restrictions on the software. I'm currently running 5 Autodesk "student" programs and the only difference I've noticed is the plot banner...nothing seems restricted. But I'm going to check on my Inventor 2011 tomorrow. I know I've manually overridden density values in the past on earlier versions of Inventor.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 29-03-2011, 21:36
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
A quick solution to changing the material density if it seems "greyed out" or uneditable, is to simply make a new material and enter the properties you want. We ended up doing this for some rather complex designs on our machine, and as long as the hand calcs are done correctly, you will get a weight within 5% of the actual.
Note: There is not supposed to be any limitations between the "student" and "regular" versions other than the plotting banner (watermark), and that you can't import a student version into a regular version (or the other way around can't remember). If this doesn't work please let me know.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 29-03-2011, 21:53
AKA: Scott
You can in fact do both, as I do almost daily with files from AutoCAD, Revit Architecture and 3ds Max. Most of the time a warning prompt it displayed when you go from student to full stating that the plot banner will remain.
Unread 29-03-2011, 22:42
M.Wong's Avatar
M.Wong M.Wong is offline
FRC #0503 (Frog Force)
M.Wong is a jewel in the roughM.Wong is a jewel in the roughM.Wong is a jewel in the rough
Are you modifying the iproperties within an assembly or the part?
