Go to Post What, there is life outside of CD? - JB987 [more]
Unread 29-03-2011, 17:38
ProgramLuke's Avatar
ProgramLuke ProgramLuke is offline
Captain
AKA: Luke
FRC #2169 (KING TeC)
ProgramLuke is an unknown quantity at this point
CRIO Imaging Tool Error 56
We are experiencing intermittent issues with our autonomous period. When we build our autonomous is works fine and scores, however after several runs it will slam our arm in reverse. We tried re-imaging the cRIO and we recieved this error:
"Unable to complete operation because
of unexpected error.
Error 56 occurred at TCP Open
Connection in repFPC open
connection.vi->Query Format.vi-
>Format Target.vi->ConfigUtility.lvlib:
ReImageTarget.vi->ConfigUtility.lvlib:
Dialog.vi
Possible Reason(s):
LabView: The network operation
exceeded the user-specified or system
time limit.
Any suggestions would be greatly appreciated.
(Code is Attached)
2012 Inaugural Minnesota State High School League State Champions
2012 Galileo Division Semifinalists
2012 Wisconsin Regional Finalists
2012 Wisconsin Regional Entrepreneurship Award
2012 Lake Superior Regional Chairman's Award
2012 Lake Superior Regional Champion
2012 Lake Superior Innovation in Control
2011 Championship Imagery Award
2011 Championship Archimedes Quarterfinalist
2011 Minnesota 10000 Lakes Finalists
2011 Lake Superior Regional Chairman's Award
2011 Lake Superior Finalists
2010 FTC World Championship Finalist
2010 FTC World Championship Edison Division Champion
2010 Minnesota 10000 Lakes Regional Chairman's Award
2009 Minnesota North Star Regional Chairman's Award
2008 Wisconsin Regional Finalist
2007 Wisconsin Regional Champion
Unread 29-03-2011, 23:51
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: CRIO Imaging Tool Error 56
There are a couple of things that can cause TCP connection errors when reimaging the cRIO. One is the Windows firewall. Another is using the Classmate with a direct cable and no intermediate router or switch device.
I found another possibility on the NI web site:
Originally Posted by http://digital.ni.com/public.nsf/allkb/922DDC440FCB15048625719D006FCB97?OpenDocument
If the controller is connected to the development PC with a cross-over cable, this error is typically caused by specifying a gateway IP address for the controller when one does not exist.
Check your network configuration and make sure there's no gateway set.
Unread 03-04-2011, 23:17
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
When I was imaging to v28 I was getting those errors. Should be a physical problem on the cRIO. The cRIO has a couple tiny switches in the front (little rocker switches) I'm not sure which ones but some of them need to be switched. There should be a help file on usfirst.org or ni.com but I'm not sure where exactly it is.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
