Go to Post I respect each member of any FIRST team that is truly trying to help students…how they choose to do so is up to them. - Jason Kixmiller [more]
Unread 30-03-2011, 20:35
Danakona's Avatar
Danakona Danakona is offline
AKA: Daniel
FRC #0597
Danakona is an unknown quantity at this point
Send a message via AIM to Danakona
Tools you can't live without
Hi everyone,
So recently we were quite fortuitous and came upon a grant that will allow us to buy some tools. We don't have much time to spend the money, so I wanted your opinions on the best tools you have in your shop, or ones you definitely couldn't live without.
So far, we're going to try to buy some more CAD software for off-season practice, a mini-mill and lathe, and some nicer hand tools that we always seem to break or lose. One team recommended a miter saw with metal blade, another recommended re-stocking our supply of various screws nuts and bolts - so we're really up for any suggestions.
We can also look towards electrical equipment and we're really open to any out-of-the box ideas, I just need them soon. Thanks guys!
Unread 30-03-2011, 20:41
jdunston94 jdunston94 is offline
FRC #3357 (C.O.M.E.T.S.)
Rookie Year: 2011
jdunston94 is a jewel in the roughjdunston94 is a jewel in the roughjdunston94 is a jewel in the roughjdunston94 is a jewel in the rough
Re: Tools you can't live without
load tester.
As soon as you start having matches where you cant charge a battery fully in between you want to be using a load tester and even if it is a full battery, says the charger it might not be good enough under load.
Unread 30-03-2011, 20:42
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
A vertical Band saw (with metal cutting blades) and a drill press I find the most useful things to buy first. After that, Taps (and drill bits), hand drill, Calipers, Squares, safety glasses, a bench top vise if you don't already have one. Once you have all that, a lathe is very useful, there is a lot of stuff you can't do without one.
What tools do you already have?
Unread 30-03-2011, 20:56
Danakona's Avatar
AKA: Daniel
FRC #0597
We just moved to a new room in our school and it came with a band saw and two drill presses - no joke. Aside from that, just some basic drills/hacksaws/taps.
Thanks for the advice on the load tester, didn't even think of that.
Unread 30-03-2011, 20:59
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Wago. Name one thing that a WAGO can't do.
...so buy 10,000 of them, so you never lose it!
More seriously, I would suggest getting a lathe, it is really extremely useful, as well as some good CAD software. Our team uses Autodesk Inventor, though that might be a bit pricey if you can't get your school to get it...
Unread 30-03-2011, 21:01
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
The 1.5k Machine Shop, 10k Machine Shop, and Machinist Starter Toolset threads are good places to start.
Unread 30-03-2011, 21:02
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
We have a small DC clamp-on ammeter, similar to this one http://www.kmstools.com/darson-instr...amp-meter-1868 that comes in really handy for monitoring how our motors are working. If you're running Jags with serial communications, and you want to write some code to monitor current consumption then you probably don't need one of these. But if you just want to quickly monitor how much current draw a motor is pulling, then just clamp one of these over the line and read it.
Just make sure you get one that reads DC current, and you really don't need one of the ones that measure up to 400A. The lower maximum values often offer higher resolution.
Jason
Unread 30-03-2011, 21:10
DonRotolo's Avatar
Back to humble
FRC #0832
OK on the band saw, get several blades right for aluminum, and make sure it will run slow enough for metal. Aluminum blades are not like those for steel - they are more like wood blades (like 6 TPI or less!)
Get a lathe once you have a decent assortment of hand tools - basically, the $250 mechanic's assortment from Sears Craftsman, with wrenches, sockets, allens, pliers, etc. For screwdrivers, we buy 3 sets of 'el-cheapo', hold one back for after build season, and throw them all away every year. Best $15 a year we ever spend...
Lathes are possibly the most handy item you can have. The mini lathe-mill products are versatile, wide-range tools that do several things, all poorly. An older, used lathe would be a far better choice for value, even for the same money.
We have access to a nice mill, and hardly ever use it. When we do, it's not really necessary, just a nice-to-have.
One thing we lust after is a CNC X-Y cutter, which can cut out shapes from flat plate, or drill precision holes. But these are rarely seen used, and can be several thousand dollars new.
Depends on how much you have to spend.
There are two threads on CD from last year, a $5000 shop and a $10000 shop, both threads have some very good suggestions. EDIT: See 2 threads above.
If you must buy new machines, Grizzly is a good mid-line choice. As long as someone is willing to learn how to set up and maintain these machines, they will give god service. Unlike a power drill, machinery like this CAN be used right out of the crate, but will last longer and work better if they are set up properly and maintained with care.
Unread 30-03-2011, 21:12
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Rookie Year: 2010
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Miter saw is a must. If you ever plan on cutting 1x1 aluminum tubing, you can't beat a miter saw.
Look into getting a break, they're pretty useful.
Unread 30-03-2011, 21:24
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
Please don't spend a single dollar on CAD software of specifically Autodesk Inventor. Autodesk provides about 30 of its products for free to students and FIRST teams.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 30-03-2011, 21:35
Vermeulen's Avatar
Vermeulen Vermeulen is offline
I have too much free time now
AKA: Tom Vermeulen
FRC #1306 (BadgerB.O.T.S.)
Vermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to allVermeulen is a name known to all
I would also suggest a good miter saw. I've found that they're much better than band saws when you need to make a square cut. Plus, they're much more steady than band saws in angled cuts.
Congratulations Ben Senson on winning the 2012 Wisconsin Regional Woodie Flowers Finalist Award!
2012 Wisconsin Regional Semifinalist
2012 Wisconsin Regional Engineering Inspiration Award
2011 Wisconsin Regional Innovation in Control Award
2010 Wisconsin Regional Chairman's Award
2010 Wisconsin Regional Quarterfinalist
2010 Curie Division Quarterfinalist
Unread 30-03-2011, 21:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
I'll vote for the compound miter saw with metal blade as well. We have a nice 10" Hitachi with a diablo blade, and it makes framing with 1" aluminum a breeze. The only problem is standard miter saw will only cut aluminum. Evolution Tools makes the FURY 3 which claims to cut steel as well, though.
Unread 30-03-2011, 22:30
Andrew Lawrence
Posts: n/a
7/16 wrenches. Life without them would be meaningless.
Unread 30-03-2011, 22:42
AKA: Scott
And 5/32 allen key
  #15   Spotlight this post!
Unread 30-03-2011, 23:04
Boydean's Avatar
Boydean Boydean is offline
The Blue Alliance
Boydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant futureBoydean has a brilliant future
Send a message via AIM to Boydean
Vim is an amazing text editor that will...oh wait, sorry.
Wire cutters. Seems simple, I know. Having bad wire cutters, though, is a sure fire way to un-inspire students to go into electrical engineering.
RJ-45 crimping tool is a tool you may never use, but when you do use it (like in the middle of competition when your tether cable gets cut with your great wire cutters) it'll work wonders.
Multimeter is a fine tool that will tell you whether or not you correctly wired your 8P8C plug on your RJ-45 tether cable.
Leaterman. When all else fails, in the end, you know you provided your team with as many tools as possible to get the job done.
Last but not least, a nifty little bag. Because you want to keep all these cool tools in the same place, why not do it in style?
Just some simple suggestions from a programmer turned electrical guy for 6 weeks.
PS. I know this thread is mainly for big manly tools, but you'd be surprised how many people don't have the basic tools.
