Switching Drive System While Driving
Odd question but can you change the drive system as you are diving?
something like this: Code:
if(joystick1.GetRawButton(2)){
myrobot.Tankdrive(joystick1.GetY(), joystick2.GetY());
Any ideas? |
Re: Switching Drive System While Driving
If you are using the Logitech Attack 3, I suggest using the "Z". So:
The "Z" is the thing at the bottom where you can push up or down. Its like a knob. if(joystick1.GetZ() > 0) { myrobot.Tankdrive(joystick1.GetY(), joystick2.GetY()); } else { //the other drive } |
so that you can do it then right?
and how would you switch back to the original drive system like this? Code:
else{
other drive drive
else if(joystick1.GetRawButton(3)){
other drive
Well, you could do something like
Code:
if (joystick1.GetZ() < 1.0 && joystick1.GetZ() >= 0.33)
// tank drive
else if (joystick1.GetZ() < 0.33 && joystick1.GetZ() >= -0.33)
// arcade drive
else // if (joystick1.GetZ() < -0.33 && joystick1.GetZ() >= -1.0)
// holonomic drive (?) ... whatever else
I wouldn't recommend using buttons to switch drive modes, as the change in speed can be sudden and you could tear up your drivetrain if the driver isn't careful and/or you aren't ramping your joystick inputs. Last edited by Dacilndak : 02-04-2011 at 22:45. Reason: Clarification. |
couldnt i do something like this so stop the tearing apart?
Code:
if (joystick.GetTrigger()){
myRobot.Drive(0)
tank drive
at least that is what i think you are trying to do |
i see what you are talking about now after i read it again couldnt we do the samething on a regular controller
What exactly do you mean by a "regular controller"? The Z-axis wheel is on all of the KOP joysticks.
If you mean just using buttons, then what you seem to be doing there (driving the motor to 0, then using the new drive mode) would certainly work. I would advise, however, adding something like a Wait(0.05); in between the two to allow the robot to come to a bit of a stop or at least slow down - by driving in the new mode immediately, the stop would be basically ignored because you'd be sending it new orders before it had time to stop. It would only stop for a fraction (1/20 in this case) of a second, but it'd really help. Try doing something like: Code:
int driveMode;
if (joy1.GetRawButton(4) == 1 && joy1.GetRawButton(3) == 0) // button 4, not button 3
driveMode = 0; // flag for tank drive
drive.Drive(0, 0); // stop motors
Wait(0.05); // let them stop
else if (joy1.GetRawButton(4) == 0 && joy1.GetRawButton(3) == 1) // button 3, not button 4
driveMode = 1; // flag for arcade drive
Code:
switch (driveMode)
case 0:
drive.TankDrive(joy1.GetY(), joy2.GetY()); // Tank drive
break;
case 1:
drive.Drive(joy1.GetY(), joy1.GetX()); // Arcade drive
break;
default:
drive.Drive(joy1.GetY(), joy1.GetX()); // Arcade drive (default, no buttons have been pressed)
break;
Also, you're transmission won't get ripped apart unless you slam the joystick from 1.0 to -1.0 quickly. Still, it's worth putting in safeties like these, since you can't trust your drivers to remember each time . |
So I should combine a if statement with a casestatment?
tomy, I'm not sure you understand the way a "drive system" works. Are you expecting to call "TankDrive" once and have the robot switch to tank drive, and later call "ArcadeDrive" once and have the robot switch to arcade drive? That's not what the functions do.
The Drive() functions take joystick inputs and mix them around to control motors. You have to call one of them at least ten times a second in order to keep your robot moving. You can decide which to use every time through your Teleop() loop, and you can change which one you use whenever you want to. I agree with the suggestion to use the Z-axis "throttle" as the selection between Arcade and Tank drive. |
#10
Ok thar sounds good I just wanted to make sure you could do it
