Go to Post Hi. My name is Rick and I am a Roboholic. - Rick TYler [more]
Unread 04-04-2011, 16:03
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
What performance can we expect from a smoked Tetrix?
I applied a little motor theory to see what we would expect when a Tetrix is smoked. (See blog post) Maybe you motor experts can poke some holes in the reasoning.
On the assumption that a smoked motor has fewer windings that reduces kt,ke and R... the smoked motor shows a higher speed at a given torque, no change in the stall torque, higher currents at all torques . So long as you can supply the current, the motor will provide more power at a given voltage.
Huh? This seems counter to what we are seeing. We know the smoked motor climbs are a little slower. If the assumptions are correct, then the reason for the slower climb must lie with the series resistance in the motor circuit. The higher currents cause a corresponding voltage drop across the series resistance and the motor voltage is smaller.
See post for detail example.
