Go to Post FIRST has stated time and again that the program is not about teaching (they always refer to the I and R in FIRST) - Dave Flowerday [more]
Go Back   Chief Delphi > Other > VEX
Unread 05-04-2011, 15:02
ESPbomb ESPbomb is offline
Junior Member
FRC #0610
ESPbomb is infamous around these parts
High Hanging Mechanism
Hello World,
I realized that a couple of robots could high hang, but this compromised their ability to score any points outside of their high hang. I was wondering if anybody had any ideas for a robot that could high hang and score goals... Any contributions would be appreciated.
Thanks
Eric Savoy-Pitfield, Team 610
Unread 05-04-2011, 15:54
SamMullen SamMullen is offline
Team Alumni
FRC #0360 (Revolution)
SamMullen is a jewel in the roughSamMullen is a jewel in the roughSamMullen is a jewel in the rough
Re: High Hanging Mechanism
Do you mean a robot that score on both the high and low pegs with ease? And does your robot have a problem with this, or are you just speaking in hypotheticals?
I'm sorry, but I am somewhat confused as to what exactly your question is.
Unread 05-04-2011, 15:59
Morality's Avatar
Morality Morality is offline
AKA: Unsh Thakore
FRC #0503 (Frog Force)
Team Role: Student
Morality is an unknown quantity at this point
I think the solution to this question is an elevator...
Always "a LEAP ahead"
R1ffSurf3r R1ffSurf3r is offline
AKA: Charlie
FRC #0233 (The Pink Team)
Team Role: Driver
R1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to behold
Hey I made a robot that could score on all goals, de-score all goals, and low and high hang (for hanging in autonomous), but I was too busy to finish it and program it because of FRC things. It used a double four-bar arm that could reach back over itself, and linear slides on surgical tubing for the last couple inches the arm couldn't lift (because of dimensions) for high hanging. I tested it and it worked very nicely.
Wish I finished it and competed it would have been fun, but in typical 233 fashion it was in a couple pieces when it came time to use it.
Unread 05-04-2011, 16:00
AKA: Charlie
Team Role: Driver
he's talking about VEX, assuming you saw this thread from the portal like I did
Unread 05-04-2011, 16:30
Team Alumni
Whoops, I'm embarrassed now. Sorry about that.
Unread 05-04-2011, 17:18
Morality's Avatar
AKA: Unsh Thakore
Team Role: Student
oops...
Unread 05-04-2011, 18:17
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Rookie Year: 2010
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
If you're talking about VRC, Team 1103 (Titan) has easily the best robot that can both score/descore and high hang. Check out this thread on vex forum: http://www.vexforum.com/showthread.p...highlight=1103
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 05-04-2011, 19:53
biancs15's Avatar
biancs15 biancs15 is offline
Driver, Design and Manufacturing
AKA: Austin
FRC #0610 (Coyotes)
Team Role: Leadership
biancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to behold
Eric,
The key to a simple, yet fast high hang lies in the use of an extremely strong elevator. To maximise efficiency, this can be put on the same arm that is used to pick up rings, or a separate elevator on the back of the robot.
KISS should be applied when you design this prototype. The simpler the better.
Best Regards,
Austin
2013 Team Co-Captain, Base driver, Head of Design and Manufacturing
2013 Waterloo Regional Finalists
2013 BAE Systems Regional Winners
2012 Arizona Regional Winners
2012 GTR East Regional Finalists
2011 Galileo Division Finalists
2011 Waterloo Regional Finalists
2011 GTR West Regional Finalists
"When in Rome"
Unread 05-04-2011, 22:17
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
Rookie Year: 2007
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
What our team found this year (355A) was that our claw arm wasn't enough power to lift up. We had a four bar with 4 296 motors, but found that although they had enough power to just about lift the robot up, it would back drive once it was all the way up (although our robot this year weighed 19.6 lbs!). We added a winch kit to each side with a 393 motor on each one and it was plenty of strength for a high hang, and the ratchets on the kits kept it from back driving. Unfortunately our team wasn't able to pull off hanging before our regional because the way the winch's were positioned, the string would run into the claw when it folded back. Also a certain other robotics team got in the way come January too...
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
