Go to Post Programmer says autonomous will work 100% perfectly...Great way to clear the room of all mechanicals and all but the boldest electricals - EricH [more]
Unread 04-07-2011, 08:28 PM
Pmaxm00 Pmaxm00 is offline
Lead Programmer
FRC #2974 (Team WALT)
Rookie Year: 2010
Pmaxm00 has a spectacular aura aboutPmaxm00 has a spectacular aura about
Saving image from Axis Camera
Is there a way to save images from the Axis Camera on the robot to the hard drive on the driver station? I've been very curious on how to do this, but I can't seem to figure it out properly :\ Any help would be useful. Thanks!
Impossibility? I accept your challenge.
Unread 04-07-2011, 08:47 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Saving image from Axis Camera
The default dashboard does this automatically. Look at the Save DB Images vi. I believe the ZomB dashboard can do it also.
Unread 04-07-2011, 09:06 PM
Lead Programmer
Rookie Year: 2010
Save DB Images vi? whats that? sorry for not knowing
Unread 04-09-2011, 08:10 AM
The dashboard is open -- you can write your own, or change the code to the default one.
The default is written in LabVIEW. If you launch LabVIEW, the Getting Started window has a template for robot and for dashboard. Once a second, the dashboard saves one image to a jpg file. This is primarily for calibration samples. It is pretty each to change how many it keeps and how often it saves.
Greg McKaskle
Unread 04-09-2011, 09:23 AM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Indeed it does, the image control (the eye in the toolbox) can save videos, right click it and say start saving, then later right click it and hit stop saving, or you can use triggers: add a Cmd button, select triggers, and guess and check on the control name, the second box should be StartSaving, or StopSaving. Our dashboard had some really nice videos (more to come soon).
It saves to C:\Program Files\ZomB\data as WebM videos (use ffmpeg or VLC to play/convert (both are installed with ZomB), open command prompt and enter this command to convert: ffmpeg -i "C:\Path\To\Capture.webm" -qscale 10 -an "C:\path\to\output.avi"
note the avi can be almost any video format, mp4, wmv, mov, etc...)
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
