Go to Post Please don't complain about the party that was thrown in your honor because they didn't use your favorite color of balloons. - Taylor [more]
Go Back   Chief Delphi > Technical > CAD
Unread 12-04-2011, 19:38
Kev101 Kev101 is offline
FTC #3826
Kev101 is an unknown quantity at this point
Constraints Lost when saving.
In Inventor How do you save an Assembly with .sat part files download from
3dcontentcentral.com without loosing its constraints?
After saving, contraints are lost and parts are able to be moved away from their place with a simple click and drag.
( The assembly saved still has its original form but loss of constraints.)
Unread 12-04-2011, 21:45
kinghashbrown kinghashbrown is offline
Lead Designer and Team tri-captain
AKA: Joey Fisher
FRC #0176 (Aces High)
Team Role: CAD
kinghashbrown is an unknown quantity at this point
Re: Constraints Lost when saving.
when you import the file into inventor it creates a copy using Inventor file types (.iam, .ipt). then when you save it will save these files to a location you chose.
thats how it has always worked for me
I believe constraints can never be saved in a .sat file just geometry. Because it is used to go between different software packages like Inventor and Solidworks.
Try searching you computer for files with the same name as the .sat file. And make sure that it is saving to .iam file type
EDIT: on my computer it saves imported files to C:\Users\(username here)\Documents\Inventor
running windows 7 and inventor 2011
Last edited by kinghashbrown : 13-04-2011 at 00:03. Reason: more info and no need for a double post
Unread 18-05-2011, 08:51
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
If you are using SolidWorks, open the part with FeatureWorks checked in Tools, Add Ins. That way you can select the geometry to be converted to become parametric. I usually select hole that are used for mounting or the overall extruded profile. You dont want to convert the entire model for they get too big.
You can also use Convert Entities to extract geometry into a sketch. Once SolidWorks sees it, the sketch will be able to be constained.
Marie
