Go to Post We need to find the female engineering mentors in FIRST and start having them present/co-present technical conferences at the championships. We need to start showing the girls on the teams that there are female engineering "rock stars" to look up to. - Kims Robot [more]
Unread 12-04-2011, 20:16
jacob9706 jacob9706 is offline
AKA: Jacob Ebey
FRC #3574 (High Tekerz)
Rookie Year: 2010
jacob9706 is on a distinguished road
arm loop stops drive
i am having the problem of the arm while loop stoping the drive
http://i1093.photobucket.com/albums/...6/Untitled.png
that is what i have and when you push the button to move the wrist it stops everything
Unread 12-04-2011, 21:26
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: arm loop stops drive
You cannot have a delay loop inside the Teleop.vi.
Teleop must execute quickly and be free to leave, because it must service 50 packets a second from the Driver Station.
If you stop it, then it won't be able to react to new driver commands.
Your delay code would work better in Periodic Tasks.vi
It can pretty much be moved, as is.
Also, your While loops must have a time delay added to each of them. Otherwise, they will run at max speed and suck all the life out of your cRIO and nothing will work very well.
Unread 12-04-2011, 22:34
AKA: Jacob Ebey
Rookie Year: 2010
thank you very much. will take what you said and apply to my code.
