Go to Post Just so you don't spend too much time on non-clues ... now you can all go back to the real one! :D - Libby K [more]
Unread 14-04-2011, 16:08
Joel Johnson's Avatar
Joel Johnson Joel Johnson is offline
zeleathos
FRC #3536 (ElectroEagles)
Rookie Year: 2011
Joel Johnson is an unknown quantity at this point
Post How do you set up a controller code
I was wondering how to set up a code that allows another controller to control a certain function. Like moving an arm up or down. The driver has control of every thing right now, and we would like to get some of it off his shoulder thanks.
Unread 14-04-2011, 16:16
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: How do you set up a controller code
If you're trying to add a new joystick, then in Begin.VI, you'll need to add a joystick open function indicating which USB port to expect it on, then wire it over to a Joystick SetReference VI and give it a name. Make it look like the one that's already there, just name it something else.
In Teleop, you would do a Joystick GetReference using the name you set in Begin.vi (spelling counts), and wire it to a Joystick GetValue (or whatever that's called - not in front of my programming PC just now). Unbundle the Axes or Buttons outputs by name as needed. Wire the output of that into your control code where the driver joystick is currently wired in, and remove the connections from the driver joystick, and you should be good to go.
Unread 14-04-2011, 16:26
zeleathos
Rookie Year: 2011
Thank you very much.
Unread 17-04-2011, 10:39
j.cole j.cole is offline
FRC #0379
j.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud ofj.cole has much to be proud of
You must have a really good driver that he has been able to drive and control the arm this whole time. I know I couldn't do it myself.
It's not normally a good idea to give a programmer a drill but rules are made to be broken.
