#76
Re: 2011 Curie Division
Alright, fine. So here's 57 along with some brief specs. Pictures courtesy Ron Gillory, http://www.sezron.com:
- Half-Octanum* drive (4 Mecanums, 2 Stickies), never measured it, but about 12-15fps in Mecanum - Pivot-telescoping arm - Spring-loaded Roller Claw, driven by two independent RS-395s through 131:1 P60s. Spring loading = Who cares about over-inflation? Also, rotating a square around the corner is just amusing. - New for Champs, 1.2s (fully charged) minibot, with a pretty reliable and forgiving deployment. Should be about 1.5-1.7 with deploy. - Reliable High-Uber Autonomous, once we work out the distances. - Regularly scoring 2 High logos by our lonesome. I'm rather pleased with the whole robot at this point. Our biggest letdown was our original Big'n'Slow(tm) minibot that didn't even benefit from reliability. We've since cribbed notes from the Discobots (2587), improving their design and working out a rather faster "align-wait-fire" style deployment system. I'm told by my students and co-mentors that I'm banned from further tweaking on the minibot, so this looks like what we're going with. The only thing I'd change at this point is the half-Octanum*. We started with a whole Octanum* and ended up about 6 lbs over, so the choice was pretty obvious. If anyone has 6 lbs of robot weight to lend us, we'd looooove to toss the other half on. As it is, we'll have it available to us at Champs to swap in some lower geared stickies, and in case of extreme emergency. (eg. Oh no, the arm's a pretzel!) *Yes, I know the accepted spelling is Octocanum. I think mine's easier to say and just as descriptive. Last edited by Kevin Sevcik : 18-04-2011 at 22:24. Reason: sp |
#77
Here is 103. With the same lift and gripper design as 25, this machine is one of the best bots we have ever created. (Pictures courtesy of Kelly Szymanowski(my sister))
The biggest problem we have is the swaying of the tower. It was designed with a spring system in the bottom, but it swayed way too much with that, so we added a strut with a dampener to make it more sturdy. That solved that problem for the most part. Other than that, I would say our second biggest weakness is our minibot deployment. It is not extremely fast, but it is reliable. The only problem with deployment is that we use the shifters to launch it out, so we cannot switch gears until the end of the match or the minibot will launch without us wanting it to. |
#78
I must ask...how did everyone get the Curie Division logos in their signatures?
#79
#82
Promo video just uploaded to YouTube.
http://www.youtube.com/watch?v=MLbaKXVKSos Robot Specs: 2 speed custom gearbox (4th Gen. 987 ball shifter design) 6w drive with lowered center wheel Single and Double tube autonomous (line following) Scores from the front and rear of robot Telescoping arm Powered Roller claw Pick up from floor or lanes ~1.3 sec minibot with deployment Less than 9 days to go!!!!!! See you all soon..... Also, highlights from San Diego with version 1 auto and minibot: http://www.youtube.com/watch?v=_MALNBCu5lw&NR=1 Last edited by twetherbee : 19-04-2011 at 02:11. Reason: Added San Diego video link |
#83
2056 and 987 will be playing in Einstein again. *knocks on wood*
#84
Thanks for that....and the compliment.
...maybe it'll be 2056, 987, and 3553 on Einstein? *knocks on wood* We're all curious to see how the unique 3553 design will fare in St. Louis. Too bad you won't be able to make it, Akash. |
#85
Dustin Benedict (mentor of 816 aka TheFro) will be taking over my position for St. Louis. I believe he will also be drive coach. Since Dustin is a driver who took down 175 and 254 in 2009, I trust his drive coach capabilities.
![]() Last edited by Akash Rastogi : 19-04-2011 at 11:38. |
#86
Wave Robotics Is excited to play on curie this Year! Our Robot info can be found at http://www.chiefdelphi.com/forums/sh...=Wave+Robotics and match videos of wisconsin are availabe here http://www.youtube.com/results?searc...onal+2011&aq=f
#87
166 made it into the elimination matches at both of our regionals this year, with out a minibot or autonomous. We are able to hang 2 top row logos each match, and now we have a 2.8-3 second minibot and autonomous so we should do well!
Us winning 3v1 in Las Vegas http://www.youtube.com/watch?v=fyOjqA2hPSQ |
#89
(my dad is the drive coach) We wanted to get more practice hanging and because it was a practice match he figured it did not matter. If you watch carfully you can se that the driver hesitates before entering the lane, he knew it was a penalty but my dad said to go so he did. |
