Go to Post Although I've never oxy welded myself, I know it is doable - jamie_1930 [more]
Go Back   Chief Delphi > Competition > Championship Event
  #91   Spotlight this post!
Unread 19-04-2011, 22:54
cziggy343's Avatar
cziggy343 cziggy343 is offline
cziggy343
AKA: Chris Z
FRC #0343 (Metal-in-Motion)
Rookie Year: 2000
cziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond repute
Send a message via AIM to cziggy343
Re: 2011 Curie Division
Originally Posted by Kevin Sevcik View Post
I assume that the shock therapy since LV has persuaded your driver to do a better job avoiding your opponent's LANE?
Aww, come on... It was just a practice match
Diamond Bullet Studios Co-Founder
http://www.dbsgames.net/index.php
  #92   Spotlight this post!
Unread 19-04-2011, 23:11
KF987 KF987 is offline
AKA: Keaton
FRC #2034 (IncrediBULLS)
KF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud of
Send a message via AIM to KF987
Thanks for the great division review Trent! Look forward to seeing you in St. Louis!
-Keaton
  #93   Spotlight this post!
Unread 19-04-2011, 23:13
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
2783's bot: (no pics yet)
Autonomous- hangs one tube (will be consistent once replacement parts come in) on high
Teleop- can hang any tube anywhere
Endgame- linear slide minibot lancher poowed by a window motor, latest minibot is held in with a cable and hitch pin system. the minibot latches onto the pole with 2 70lb (force) wind turbine magnets. current minbot goes up in 4 seconds (a direct drive version may be made)
mechanics:
drivetrain: high speed mecanum (4x cims/ TB nanos). it is normally run at 50% power for preciceness and rant at full poer for speed when the "turbo" trigger is held.
arm: the robot uses a 3 stage arm controlled by 2 geared down BB 550's and 2 springs. all 3 segments work in sync by a cable/pulley system. a 550 or an FP will be on the wrist and the gripper also has a bb motor (forgot the model). the arm, wrist, and gripper all have analog encoders for precise preset positions.
the robot has a low center of gravity (it has never come close to tipping).
the robot has a direct fed (though AP, bypassing the cRIO) camera, controlled by a tilt servo (180 degrees). the current code (perfected tonight) gives drivers real-time video with crosshairs for guiding when the camera is facing forward, and when it faces backwards (to launch minibot), the crosshairs switch to 2 vertical lines (to line up with pole) and the image rotates 180 degrees. the tilt angle is set by the driver's righthand throttle.
the current arm (not used in regionals) is being used on a practice clone chassis, and at 23lb, it will be brought in as withholding allowance material.
Good luck to curie!
Minibot- linear slide launcher (cab
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
  #94   Spotlight this post!
Unread 20-04-2011, 13:29
aboppana's Avatar
aboppana aboppana is offline
Abhishektha
FRC #1923 (The MidKnight Inventors)
Team Role: Leadership
Rookie Year: 2010
aboppana is just really niceaboppana is just really niceaboppana is just really niceaboppana is just really niceaboppana is just really nice
Team 1923's robot specs:
Reliable autonomous with scoring on top row (has only failed to get points once at CT)
Can score on all three pegs and averages about 1-1.5 logos per match
Has set the high score at NJ of 124 with teams 25 and 1860
Has set the high score at CT of 123 with teams 195 and 155
Third seed at NJ, first seed at CT, winner at CT
~1.3 second minibot w/o deployment (wasn't there at jersey), not timed w/ deployment, estimated 2 second deploy and climb
The inspiration for this minibot is from Team 40(Trinity Robotics from Manchester NH). Thank you for being gracious competitors and helping us out!
Here's some video of us in action:
http://www.youtube.com/watch?v=1G62Ds2riHA
and pictures:
http://farm6.static.flickr.com/5180/...71e5e608_o.jpg
http://farm6.static.flickr.com/5092/...9f70d16a_o.jpg
http://farm6.static.flickr.com/5131/...bbb7d6e4_o.jpg
SEE YOU GUYS ON THE FIELD!
  #95   Spotlight this post!
Unread 21-04-2011, 18:16
Megan514's Avatar
Megan514 Megan514 is offline
improbablewhale
FRC #2059 (The Hitchhikers)
Rookie Year: 2011
Megan514 is an unknown quantity at this point
Can't wait! Team 3459 is an all rookie team. None of us have never done this before! We placed 7th out of 52 at our regional, and are thrilled about going to St. Louis. We think we have a pretty good robot. We were going to borrow a minibot from a team at the NC regional, but we never got in contact with them. Don't know how we'll do, but we'll see! See you all in St. Louis!
  #96   Spotlight this post!
Unread 21-04-2011, 18:29
Josh Drake's Avatar
Josh Drake Josh Drake is offline
Engineering Mentor
FRC #5403 (Aluminosity)
Rookie Year: 2007
Josh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond reputeJosh Drake has a reputation beyond repute
Glad to see you guys in our division. First time for all of us in St. Louis, so we are all noobs in a way.
07'-10' FRC 343
11'-12' FRC 2751
13'-14' FRC 3494
15'-16' FRC 5403
  #97   Spotlight this post!
Unread 22-04-2011, 11:54
If you guys have the parts available (motors, limit switches, c channel, bushings) I think plenty of teams would help you put one or two together. 3553 used to have a pretty ghetto looking minibot that still went up in 1.5 seconds that they could probably help you build.
  #98   Spotlight this post!
Unread 22-04-2011, 14:02
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
57 is going to have a few extra minibots, and we have an extra, slightly crooked deployment system as well. Find me in our pits around 6 on Weds and we'll talk.
  #99   Spotlight this post!
Unread 22-04-2011, 15:49
Blackphantom91's Avatar
Blackphantom91 Blackphantom91 is offline
Mentor + 4 = Stuck For Life
AKA: Malcolm Stirckland
FRC #1986 (Team Titanium)
Blackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura aboutBlackphantom91 has a spectacular aura about
I wouldn't be opposed to helping you build one! pm if interested or find me at champs wearing a team titanium shirt and a hat(I'm literally going to wearing that.).
[img*]http://i.imgur.com/Os2oTET.jpg[/img*]
  #100   Spotlight this post!
Unread 22-04-2011, 16:22
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
Team Role: Coach
Rookie Year: 2007
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
Ahhh!!! Giant Mexican Hat in potentially uber crowded pit field bleachers.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
  #101   Spotlight this post!
Unread 22-04-2011, 16:33
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
It looks like they already have a deployment system (that works, I saw them deploy in a QF match video). Unless of course that was a loaner, too (considering it has a different minibot on it in the pic (prob theirs in Qual 14) and vid (prob loaner) I think it is their system). I think they should probably choose which ever minibot fits their deployment the best, so lets give them options.
I offered them one of our loaner minibots as well via PM (to a couple members of their team). I think PM is probably the way to go (for other to offer minibots) since members of their team might not read the rest of this thread. I have a read receipt but no responses yet.
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
  #102   Spotlight this post!
Unread 22-04-2011, 17:38
Megan514's Avatar
improbablewhale
Rookie Year: 2011
Thanks everyone willing to help! Our team is meeting tonight, I'll bring it up
  #103   Spotlight this post!
Unread 22-04-2011, 18:46
twetherbee twetherbee is offline
Mentor, Team 987
FRC #0987 (High Rollers)
twetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud oftwetherbee has much to be proud of
Just in case anyone missed our other thread, we have posted a link to our Curie robot photo database that everyone is welcome to utilize. Keep checking back here as we will continue to add the missing pictures.
http://www.chiefdelphi.com/forums/sh...threadid=94758
We pulled these pics from team websites, other CD posts, and have now resorted to screen captures from YouTube clips. So, if we don't have a photo or it is not a very good picture of your robot, we apologize but you've hidden them well....
  #104   Spotlight this post!
Unread 22-04-2011, 21:58
Rookie Year: 1998
Mmmmmmmm... I'm a newly minted fan of the deployment systems that extend a rail with an alignment device, and then fire the minibot down the rail.
I don't know about other non-magnetic, direct-drive minibots, but ours is sensitive to misalignment. If the deployment system pushes the minibot sideways against the pole, then there's too much pressure on one roller, not enough on the other, and the minibot just spins out. Plus all the concerns about bending shafts and such. So while I'm willing to loan out minibots, I'd also like to set up the loanees for success.
  #105   Spotlight this post!
Unread 22-04-2011, 22:19
LShank LShank is offline
FRC #3492 (RoboGens)
Rookie Year: 2011
LShank is an unknown quantity at this point
Team 3492, RoboGens, is another Rookie team that is excited to be going to St. Louis next week!
