Go to Post Someone tried throwing out a perfectly good fleece blanket! It even had the quadratic formula on it! WHY ON EARTH WOULD YOU THROW AWAY THE QUADRATIC FORMULA?? - Karibou [more]
Unread 16-04-2011, 18:58
114Klutz 114Klutz is offline
AKA: Li Pi
FRC #2984 (Viking Robotics)
114Klutz is a jewel in the rough114Klutz is a jewel in the rough114Klutz is a jewel in the rough
Send a message via AIM to 114Klutz
1 Second Minibot - Rampless.
https://www.facebook.com/video/video...13147&comments
Edit: if you can't view it, use this link.
http://static.ak.fbcdn.net/rsrc.php/...586213147&ev=0
This footage was taken with a high speed camera at 600fps. It's been slowed down to 60fps.
2984 will be on Archimedes. Deployment is sub 100ms.
Unread 16-04-2011, 23:33
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
Re: 1s no ramp minibot - team 2984.
Wicked fast, should make for some good competition. Just wondering, does it always fall off after hitting the top?
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
Unread 17-04-2011, 01:01
AKA: Li Pi
It tends to do that on the practice pole. On the real pole, the top pushes inwards a bit, and pushes the thing back down. It's less likely to fall off.
But we need to do testing on that.
Unread 18-04-2011, 18:26
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I would love to see the deployment system if you would like to share. Sub 100ms is very impressive for deployment.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 18-04-2011, 19:02
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: 1 Second Minibot - Rampless.
Would you mind posting a few specs?
- weight
- wheel(shaft) diameter
- normal force
- did you measure the rolling friction?
- etc
Unread 18-04-2011, 20:27
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Any chance it would be able to make a second run if no-one had been there to catch it? I have seen several videos of super fast bots that fly off the pole once they hit the top. unless these bots are tougher than they look, I forsee dead bots all over the field, with none left by elims....
Former Mentor Team 1771
Former mentor Team 4509
Unread 19-04-2011, 03:13
AKA: Li Pi
This bot could be faster. It's meant to survive falls, and it's actually built quite heavier than it should be. It also, on an actual pole with a sprung top plate, will stay on the pole while falling downwards. The bottom of the minibot has two collapsing cylinders that act as shot absorbers for that.
Plus, we have 4 minibots, and enough C-frame to make at least 10 more at competition.
Drag was estimated, and we binary searched the shaft diameter after doing a bit of math to narrow it down to the correct spot. I'm not sure we're entirely at the optimal point.
The deployment system is two stage - predeployment pops out a tray on a turret that automatically aligns and pushes against the base. The second stage is merely a sled on rails containing the minibot, its powered by surgical tubing. It is very fast.
You can probably find a closeup in one of our matches at regionalwebcast.com during the Vegas regional.
Edit: heres an image.
deployed:
