Flakey Victors
Posted by Mike McIntyre, Coach on team #47 from Pontiac Central HS.
Posted on 3/5/99 11:17 PM MST Caution: if your Victors are acting flakey, it may be because they have gotten flakey. Delphi C/A from Flint tipped us off to this when two of our Victors started acting up: we opened them up and found some metal shavings inside that had somehow slipped past our shields when we were drilling on our machine. A ray of hope: sometimes the act of cleaning them out allows them to resume normal operation. |
Re: Flakey Victors
Posted by Tom Wible, Coach on team #131, chaos, from central high school manchester and osram-sylvania.
Posted on 3/6/99 10:43 AM MST In Reply to: Flakey Victors posted by Mike McIntyre on 3/5/99 11:17 PM MST: Sounds more like metal flakes, than metal shavings!!!! I wonder if the metal part of the MOSFET is live? The flakes would probably not be good for them at that point. We had what we thought was a bad fan on one of our Victors, turned out to be a lug had fallen into the fan and was impeding its' rotation. Quick removal saved the fan. Tom Wible Team 131 "C.H.A.O.S." |
Re: Flakey Victors
Posted by Andy Grady, Coach on team #42, P.A.R.T.S, from Alvirne High School and Daniel Webster College.
Posted on 3/6/99 7:17 PM MST In Reply to: Re: Flakey Victors posted by Tom Wible on 3/6/99 10:43 AM MST: What exactly were the Victors doing when you had this problem. Were they totally dead? Or did you get a flashing light? I would like to know, because i haven't yet opened up the Victor that went out on our machine, and it would help if i knew what the problem was. thanx Andy Grady |
problems can vary
Posted by Joe Johnson, Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 3/6/99 8:05 PM MST In Reply to: Re: Flakey Victors posted by Andy Grady on 3/6/99 7:17 PM MST: The problems were various. One thought it had a good nuetral signal even when there was no signal wires connected to it. I don't recall what was wrong with the other, but it was something completely different. Joe J. |
Re: Flakey Victors
Posted by Bob Weiss, Engineer on team #54 from Hoboken HS and Stevens Institute of Tech.
Posted on 3/6/99 7:58 PM MST In Reply to: Re: Flakey Victors posted by Tom Wible on 3/6/99 10:43 AM MST: The metal tabs on the MOSFETS are connected to the center lead (drain). Definitely a hot terminal, with a LOT of current available if shorted out. Be careful with dropped hardware! : Sounds more like metal flakes, than metal shavings!!!! I wonder if the metal part of the MOSFET is live? The flakes would probably not be good for them at that point. We had what we thought was a bad fan on one of our Victors, turned out to be a lug had fallen into the fan and was impeding its' rotation. Quick removal saved the fan. : Tom Wible : Team 131 "C.H.A.O.S." |
| victors | great_one411 | Electrical | 4 | 06-02-2003 09:08 |
| Questions..... | archiver | 2000 | 1 | 24-06-2002 00:22 |
| What subtitutes controllers, radios, Victors and Spikes? | Digo | Technical Discussion | 6 | 15-05-2002 16:04 |
| DON'T Recalibrate Victors! | Joe Johnson | Off-Season Events | 0 | 12-11-2001 22:58 |
| Some questions and answers... | Joe Johnson | Off-Season Events | 0 | 26-10-2001 12:56 |
